Intermittent Overheating Help
Old 05-28-2007, 05:23 PM
SS_Shanker's Avatar
Default Intermittent Overheating Help
Just bought 99 Camaro SS less than 2 months ago. Normal driving seems to have small amounts of boilover from the reservoir on long trips the car holds normal temp while i am moving on highway. Once i make stops for tolls the cars temp begins to rise and i shut it down at 260. After letting it cool i can again drive the car and it holds a steady 210 but each time i stop it begins to overheat.
Thermostat new, hoses replaced, system flushed and pressure tested. Does anyone have any idea what could be causing this?
Old 05-28-2007, 05:36 PM
2001NBMZ28's Avatar
Assuming the fans are coming on and there's no air in the system, something easy to to is replace the radiator cap - maybe it's not holding pressure?
Old 05-28-2007, 08:13 PM
SS_Shanker's Avatar
Would I see the coolant by the reservoir if the cap was bad?
Yes both fans are working.
Old 05-29-2007, 01:18 AM
staringback05's Avatar
you might have some air in the system....
Old 05-29-2007, 01:21 AM
waldershrek's Avatar
Sounds like air in the system to me
Old 08-05-2007, 11:16 PM
SS_Shanker's Avatar
Default Been away for a while
Simple fix in the end...radiator cap as suggested first. Thanks for the help!
Old 08-08-2007, 06:31 PM
ricardo colon's Avatar
GET THE ONE THAT SAYS VENTED
