clutch master mod
Its called the drill mod and all you do is drill out the little restrictor that is in the braided line that runs from the master to the slave. It will help in clutch engagement especially when racing. It should be a first mod for everyone with a manual trans.
Pretty much you have to just pull the master cylinder out of the car and disconnect the braided line from it and then use a 1/8th drill bit to drill out the restriction in the line. Its an easy mod.
Heres a link. http://www.installuniversity.com/ins...sity/index.htm
clutch master
thanks i thinks its a little late i blew the cluch tonight at the track should i get a centerforce?
