corvette filter and reg
what is the best way to come out of the filter and go to 6an line? my fuel setup is a walbro 255 pump, 99 corvette filter/reg, and the jegs 6an push lock line and fittings between everything i know i can us the russels disconnects on the inlet side and return am up for any other ideas before i order everything thanks for everyones info
There are many ways of installing the vette Filter/Regulator, search the Forum and FAQ/Sticky.
This thread might help also, in place of the Russell Q/D.
https://ls1tech.com/forums/conversions-swaps/652827-some-more-pics-corvetter-filter-fpr.html
Also on my Cardomain site.
http://www.cardomain.com/ride/2353903/10
I use Russell Q/D to AN -6 on the Inlet and return tubes, then use a Russell Compression to AN -6 with a old peice of tubing that has the correct OEM barb on it. This short peice of tubing can be picked up at most parts stores that carry the Dorman line.
