Some more pics of the Corvetter filter/FPR
For future reference here are some pics of the Corvette filter/FPR (NAPA Part #3737) and the Dorman 800-120 and 800-121 the connectors for the inlet side of the filter. I couldn't find Dorman 800-155 which connects to the filter outlet.
I had no idea how compact the FPR was![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://img129.imageshack.us/img129/9745/inletwn8.jpg)
![](http://img294.imageshack.us/img294/9485/dsc03435kn6.jpg)
![](http://img259.imageshack.us/img259/1166/dsc03436lr9.jpg)
![](http://img522.imageshack.us/img522/2930/dsc03440my6.jpg)
![](http://img294.imageshack.us/img294/1238/dsc03441kt2.jpg)
![](http://img176.imageshack.us/img176/6883/dsc03444me2.jpg)
![](http://img174.imageshack.us/img174/8329/dsc03445je7.jpg)
Looks good. How much did you have to give for those handy pieces? I need to pick mine up but if I understand correctly different year engines have different fuel pressures. I haven't purchased my engine yet so I have to wait.
Hows your swap going?
Originally Posted by rao
The filer was around $5; each of the connectionr around $10. I am fairly certain that all LS1-2s use he sme fuel pressure - 58 psi or 4 bar.
here are some pictures using the Russell AN to GM fittings on the FPR inlet. I used the Dorman tube on the outlet, and a Swagelok union to connect it to a new 3/8 stainless line from Rick's.
![](http://www.blown.net/ls1swap/DSCF3937.jpg)
![](http://www.blown.net/ls1swap/DSCF3938.jpg)
The filter was around $50; each of the connectionr around $10. I am fairly certain that all LS1-2s use the same fuel pressure - 58 psi or 4 bar.
https://ls1tech.com/forums/showpost....80&postcount=2
It states that some use 26lb injectors and some 28lb injectors. I had expected this meant they ran at a different fuel pressure. What's the 26 and 28 lb? If the pressure is the same and the injectors different then Does this mean that the pulse width suplied is different to get the same output volume (in other words the PCM's not interchangeable)? Oh my head hurts.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Good news is that if they are the same I can add these parts to my shopping list
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
