Shift light installation
It has red/black/green wires. Red is suppost to go to a 12V ignition switch. Where do I hook up the red wire too, like where on the car. Black goes to a good ground. And Green goes to either negative coil on ignition or to the tach terminal, which I assume is on the PCM. Can someone help me with the red and green wires? Thanks.
Ungrounded Moderator
The wonders of search...
https://ls1tech.com/forums/showpost....72&postcount=1
(It's for a Raptor shift light but they all work basically the same.)
