Best Suspension mod for better 60ft?
I have a 1995 383 lt1 3600stall 3.73 rear drag shocks no sway bar in the front, everthing else in the suspension is stock what mod would give me the best 60ft gain? best 60ft 1.65 on m/t et streets.
I would have to say a torque arm. Since this is mostly a drag car, look for a shorter torque arm rather than longer. Since you have the tire to handle it, you can take advantage of the shorter arm's ability to hit the tires harder.
Originally Posted by kline454
anyone use the Jegster 40095 Torque Arm For 1982-2002 Camaro/Firebird?
LCA relocation brackets will help also
Originally Posted by 02NBMWS6
if youre gonna get a torque arm, buy a good one the first time. I recommened UMI's chassis mounted one with the driveshaft loop.
Stay away from the Jegster one. Requires removing some of the interior to install, gets in the way of some stuff under the car, and they break. Buy a quality piece
