getting close to 11s, running it 6-7-07
I figured i'd get some input from you all- Will it be enough to make 11.99?
I ran a 12.47@ 113.46 mph with a 1.97 60' on street tires, & 10bolt w/ stock 342 gears ( i know i couldve hit 12.3 that night but only had 2 runs)
this time-
i should have my drag radials on
I have a moser 12 bolt w/ 373s now
Im gonna remove my broken a/c pump and condensor. also, the front swaybar, but will be putting it [the swaybar] back in when i get home. i figure those itemes. EDIT-- dropped another 74 lbs off the car today,
if i drive up solo, i will also remove the pass seat. ? lbs?
Even a really good friend of mine is going to replace my stock tune file with a better basic tune file (until i get a WB O2 to really go all out)
the only problems i can see is that the high temp is going to be 81 degrees on thursday, low 62. (warmer than when i ran in april) and i figure it should still cool down some by the end of the night.
Im bascially a full bolt on car, and i have the driver mod as well.
this time-
its possible, but may be hard to do in this heat.
the pass seat weighs about 54lbs.
the car also drives fine w/out the swaybar on.
if you pull a mid 1.7 60' you may have a good shot of hitting the 11s.
ill give you some pointers tommorrow nite at the track
-brandon
-brandon
well i ran a 12.26 @ 114.18mph 1.81 60' 7.92 1/8th @ 90.26 mph boggin off the line, 1500+ DA
2nd run 12.29 @ 114.72mph 1.98 60' 7.98 1/8th @ 90.79mph spinning off the line...
3rd run fell on its face, 1.9 60' 12.3 @ 114 mph
4th run wouldve been 11.9 or 11.8. I cut a 1.85 60' bogged a lil, 1-2 mis shift cost me 7-8tenths which gave me a 12.6 on that run arg!
yeah it was my last run, and i didnt notice that they moved the cone aside either, so i was in the groove!!! and i hooked so hard i was like im thinking to myself, "im gonna do 11's" and then missed a shift and man, i was soo pissed!
