Tweak Fan on Temp setting with stock thermostat?
I've read a few post concerning a "missing" table that the most current version of LS1EDIT does not have. It is "Spark vs Coolant Temp" http://mywebpages.comcast.net/gdouma...oolantTemp.xls
Since timing starts to get pulled around 230 degrees F, I wonder if I set the FIRST Fan on Temp to lower than 229 (which is the stock setting)
What temperature does our stock thermostats open up at?
Tommy
Tommy
Moderator
Re: Tweak Fan on Temp setting with stock thermostat?
My stable coolant temp is 194-197F with the
stock 'stat. I set my low fans to be turn on
5 degrees below this temp and high fans 10
above it.
I would really like to see a printout of this
stock spark-vs-ECT table, just for my own
edification.
above it.
edification.
I posted the link above of the entire table!!!
Here it is again:
So what are your exact fan setting now? On/Off for Low/High. I just don't want my fans to stay on all the time...
Thanks!
Tommy
Here it is again:
Thanks!
Tommy
Location: Richmond, VA Where fast cars, well......are hard to come by.
I set mine for 200 and 205. Worked much better. Now since I have just a single fan that cuts on at the low temp, it cools quicker.
