Catalytic Converter power loss?
Old 06-07-2007, 03:27 PM
RBS_97Z28's Avatar
Default Catalytic Converter power loss?
I had to put a Cat on my exhaust yesterday so the it would pass inspection here in Missouri. It's a 3" universal hi flo and I was wondering how much HP am I losing?
Thanks
Old 06-07-2007, 07:58 PM
taintedmeat's Avatar
3 hp?
Probably not a whole hell of a lot. Cats aren't the huge detriment to power a lot of people make them out to be, and after-market cats are even less of a restriction.
Old 06-08-2007, 07:39 AM
RBS_97Z28's Avatar
That's what I was hoping to hear. It muffled the sound a little, but not too much. I put it about 16" behind the ORY. I was thinking of taking it back off and clamping a 3" straight pipe, but not sure if it's worth the hassle now.
Old 06-08-2007, 08:20 AM
You probably don't notice much of a performance difference do you? The ideal situation would be to have a separate cat for each cylinder bank, but a high flow cat at the end of a y on a mostly stock motor shouldn't be much of a restriction.
Old 06-08-2007, 08:33 AM
RBS_97Z28's Avatar
No, I really don't feel any loss at all, just a slight sound reduction.
Question, why would 2 Cats per each bank be better than 1? That's something I've been trying to figure out since the '96 Z28's came with 2 and claimed more HP.
Old 06-08-2007, 08:48 AM
If you have one behind each cylinder bank on a dual or ypipe setup then each cat only has to deal with half as much exhaust gas passing through it, so even less chance of a flow restriction. Would also most likely prolong it's life a bit since 2 wouldn't have to work as hard as one to produce the same result.
Old 06-08-2007, 09:07 AM
SmokeySS's Avatar
That's an interesting place to put 1. They're meant to be up forward so they can pick up and retain heat to burn off any dumped fuel.
Old 06-08-2007, 09:09 AM
They'll work back that far though. On my 96 Dodge it had two cats right in front of the muffler, which was up under the bed. Never had any emissions issues with it.
Old 06-08-2007, 09:41 AM
RedWS6 00's Avatar
For an inspection check dont the cats have to be in the stock position? or is this just particular counties?
Old 06-08-2007, 12:37 PM
RBS_97Z28's Avatar
The inspector told me as long as it's in front of the Muffler it's okay.
Quick Reply: Catalytic Converter power loss?
