Engine Stumble
Engine Stumble
I have a '99 Z28 6 speed with 70,000 miles, that is stock besides gears and a Lid. The engine stumbles whenever I change gears or accelerate, but then it's fine after that. It does not miss and the check engine light has never come on. I took it to a local dealer and they were no help. A buddy of mine says it sounds like a sensor, but without a code he has no idea either. Anyone have any ideas???
I have had the t-stat and filter replaced. I also had the injectors cleaned. I was told by the local dealer that the plugs didn't need to be changed until 100,000 miles. I just not sure about waiting that long though.
Oh yeah, change the plugs. They are platinum, which really doesn't perform well. Go with some NGK TR-55's. BTW, do plug #8 from under the car and do that one first. You'll thank me later.
And no more dealer. If you need to go to a mechanic, find one that does LSx stuff. Most dealers know less than the owner of the car, especially if they are an enthusiast. If there isn't a code on the computer which is the case many times, they can't fix it.
They told me since there was not a code the only thing that they could do would be to hunt down the problem at $70 an hour. I have two performance shops about an hour and a half away, Thunder Racing and Futral Motorsports ( Futral being the one that installed my gears), I just don't have the time to get my car down to them. Seeing what I have done so far what should I do next ( after fixing the stumble )?
Catback exhaust and getting yourself HP Tuners. You could pay to have it tuned, but it costs the same if you do it yourself and you can do it whenever you want which is better. Plus lots of guys will help you out if you have questions.
This is very bad advice.
This is very good advice.
Lot of opinions on the right plug. But you have got to change them. Run Search and see what comes up. This is a well discussed issue.
