Spec stg 4 or stg 5.... Help me decide!
Old 06-12-2007, 12:29 AM
Speedy0009's Avatar
Default Spec stg 4 or stg 5.... Help me decide!
It'll soon be time for a new clutch for my car. I have been trying to decide between the Spec 3+, stg. 4 or stg. 5.
I put about 4K miles on my car a year.. give or take. I will be Drag racing it more and more, especially once I have my own trailer (couple weeks hopefully)! I will be throwing 530rwhp/440rwtq at it for now and probably 600/550 later and of course on slicks!
It's been recommended that I go with the 3+ for streetability and a solid clutch at the track.. but I question the life of it with the power I'll be putting through it and the use of ET Streets with a 4100lb car. So I have been searching to see the results of the unsprung hubs on the stg4 and stg5 clutches from Spec. I have only found a couple threads here with short reviews on the stg 4.. anyone else??
Please let's not turn this into a Spec bashing thread... I'll just delete it!
Thanks in advance!
Todd
Old 06-12-2007, 09:19 AM
10 Second Moderator
Torkman15's Avatar
I'm running a Spec stg4 with a solid hub and have made 50 or so passes on it and when I had it apart this spring to install my blowproof bellhousing it looked like it was barely broke in. I'm very happy with it, pulls like a freight train. (Similar HP figures as you 3400# car 4.56 gear) When I had it all apart I took my trans to Liberty to go from proshift to faceplate engagement and they said that solid hub is hard on parts and I should switch to a sprung hub like a 3+ (cant afford that right now) Good luck to ya..
Old 06-12-2007, 09:53 AM
Stang's Bane's Avatar
If you want the best solution from Spec, look to one of their twin-disk setups.
As far as the others go, the 3+ has the tq rating to handle what you want, but I would say the other 2 would last longer. It is a tossup, the street manners of the 3+ vs. the increased longevity of the sintered set ups.
Good luck
Old 06-13-2007, 12:00 AM
Speedy0009's Avatar
Thanks guys for the good information...
Anyone else?
Old 06-13-2007, 02:26 PM
mike c.'s Avatar
The only clutch that lasted for me was the spec st3+. 10.27 on slicks 590hp 650tq. It never went out on me,but since i have a new motor going in I threw a new clutch in anyway.
Old 06-13-2007, 05:55 PM
Drewstein's Avatar
3+ here. I ran one hard as hell at 600rwhp with not one issue.
Old 06-13-2007, 11:03 PM
Speedy0009's Avatar
hmm... really sounds like the Spec 3+ is the one for me then! Decisions, decisions..
Keep it coming guys!
Old 06-16-2007, 01:37 PM
nitrorocket's Avatar
Spec 5 sucks on the street, you can't slip it and it will squeel if you do, great for a drag car I would say.
Old 06-16-2007, 09:08 PM
Nice SSer's Avatar
Couldn't have said it better myself.
Quick Reply: Spec stg 4 or stg 5.... Help me decide!
