Heads/camp install, will it run with 42lb injectors before tune??
Ok I just bought the TSP 5.3l/stg. 2.5 heads and a MS3 combo. I purchased lucas 42lb injectors and was wondering if the car will run with the new injectors or would I be better off intalling the stock injectors(2002 camaro) and then changing them out when I get to the tuner. I know either way its going to run like crap until I get it tuned, I just need it to run long enough for a proper break in/heat cycles and to drive it to the tuner. Thanks'
-William
-William
I'm running my stock injectors (02ss) with an ms4 and ls6 heads. Had 38's to go in, but my tuner told me that i didn't need them. Then when they tuned it they said i still had another 50hp left in the stockers. Your fuel pump will run out before you injectors will (if its tuned properly).
When I did mine, I drove down to the shop with the stocker and put the #36 in the shop before they tune the car. I asked the same question a while ago and most people don't recommend it. You can actually do some damage by washing the cylinder walls too much.
