View Poll Results: swap 98 pcm to 99+ worth it?
YES worth it!
5
100.00%
No not worth it!
0
0%
Voters: 5. You may not vote on this poll
Swap or not to Swap 98pcm to 99+
Old 06-13-2007, 03:45 PM
lilicedout24's Avatar
Question Swap or not to Swap 98pcm to 99+
before some of u say use the search option i have and i have read my self to damn sleep so bottom line is it worth it doing the change?
Old 06-13-2007, 05:46 PM
Doc
Doc's Avatar
Depends on what your goals are?
Old 06-13-2007, 07:16 PM
98SS1LWEE's Avatar
Well, unlike everyone else i guess...My search sucks frequently, so help me out, what all has to be changed when doing this.Engine harness, PCM, What else?
Old 06-13-2007, 08:20 PM
Shallow Bay's Avatar
There's no need for a new harness. The one currently in your car will work just fine. However, you will need to remove almost all of the circuits from the red and blue connectors and repin them according to a later PCM. The only other thing you will need is a new PCM. Here's a few links with excellent information regarding the swap.
http://www.ls2.com/boggs/torques/98pinpcm.htm
http://www.ls2.com/boggs/torques/99pinpcm.htm
https://ls1tech.com/forums/pcm-diagnostics-tuning/711711-98-formula-pcm-99-pcm.html
http://forum.efilive.com/showthread.php?t=4964
Old 06-13-2007, 08:35 PM
Doc
Doc's Avatar
ShallowBay is correct with one caveat...If you or your tuner is using EFI Live.
Without it if you want the fuel gage to work you will have to swap the cluster and sending unit in the tank. Unless a HPT peep has an update, I don't believe you can swap calibration segments.
Old 06-13-2007, 09:50 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm going to try and read up on this some. Seems like it would be a good time to do it now that my car's down and everything is going to be coming out anyways.
Old 06-14-2007, 01:07 AM
I don't know how the fuel gage issue slipped my mind as I'm fine tuning it right now.
Old 06-14-2007, 01:27 PM
ok what are the benifits of doin a change over? more horses or just a easy tuning
Old 06-14-2007, 01:48 PM
Doc
Doc's Avatar
No more horses alone. Now if you are going to do H/C or some sort of power adder, N20, Forced induction, Turbo there are plenty of reasons to do this.
H/C- drivability, more tables for you or your tuner to smooth out your ride
N20- Be able to change your tune at the flip of a switch-pull timing/add fuel for safe spraying. Max motor tune, then flip switch for N20. Free and exculsively for EFI Live users.
FI- Added resolution / range. Once again, free for EFI Live users.
So that is why I originally asked you what your plans were/are for your car. If you are just going to stick with bolt-ons and not dive into the motor with a cam or whatnot then the 98 OS will serve well enough.
Old 06-14-2007, 02:24 PM
OWN3D BY MY PROF!
Here's an odd question, but relevent. I'm partially color blind how much more difficult would this be for me? It's mostly blue and purple, but other colors red / green / brown sometimes give me troubles.
Old 06-14-2007, 03:24 PM
Eurospec2's Avatar
Doc would know better then me, but if you can count and are very very careful when you remove wires from the connector color blind shoudnt be a problem, IE if you pull pin 25 from the red connector and label it then the wire colour shoudnt matter, but if you pull 3 wires at once and get them mixed up, you may not be able to tell them apart.
Old 06-14-2007, 06:33 PM
zapp168's Avatar
You must know someone that can help you that is not color blind? This is better as a two man job anyway. I sat and read down the list while my friend jabbed the wires in, lot easier than read stop...plug....look at the list...lose place...etc... I mean you can do it alone but you are just going to have a harder time locating the wires quickly as you will be relying on the labels more
Old 06-14-2007, 07:03 PM
ok thankx. im going with a MS4 410,s all bolt ons 150 shot thats it if that aint gettin me 11.9 or better fucXX it ill sell it.
Old 06-14-2007, 07:04 PM
oh and true duals
Old 06-14-2007, 07:44 PM
Doc
Doc's Avatar
You should be able to get the 11.9 with the MS4 alone at sea level. Yes, your car/application would be much more enjoyable all around by going with the newer pcm.
