Installed Konis and Strano springs.
Well I installed the new shocks and springs yesterday. Its handles alot better. I still have to get an alignment though that will probably make it a littler better. But It seems like the ride is rougher now. not much it just seems like it takes bumps harder now than it did. Is it like this for everybody? I have the rears set a full soft and the front 3 sweeps from full firm. It couldn't be that I installed something wrong could it? I'm pretty sure I installed everything right. The Strano springs didn't have to be compressed to get them back on...Thats right isn't it? Thanks for the help guys i'm just trying to make sure everything is how its suppose to be...
LS1TECH Sponsor
If you have more than about 32 front, 30 rear in the tires, it's too much. 3 sweeps from full stiff is stiffer than I personally run my shocks, might try backing that down a bit. You did add springs that are stiffer than stock. 292/115 are stock kind of rates, now you have 550/150. Lowering springs aren't what you want for a Cadillac ride, stock springs are best for ride quality. And I'm wondering if the front shocks were on the upper spring perch position. If not they need to be.
__________________
I now have the fronts turned 5 sweeps from full firm and it rides so much better. Just putting that out there for future Koni owners. They really are great shocks. I guess the great Strano springs help.
Copy & Paste Moderator
Originally Posted by dopy
I would like too see some before and after pics
Please add them to this thread too:
https://ls1tech.com/forums/suspension-brakes/725347-does-your-car-have-best-stance-come-inside.html
I will try to get a pic here pretty soon. I don't have any before shots. Well I do but its with different rims and everything. Where does everybody measure from? Top of fender well to the ground?
