Is this idle behavior normal?
Old 06-17-2007, 02:18 PM
Grimery's Avatar
Default Is this idle behavior normal?
2001 WS6 M6.
*Important*
This only happens if the AC is on
*Important*
Most of the time the car will idle correctly, around 800 on the speedo.
Randomly, it will idle at 1000-1500. After awhile it will drop back down but it'll sometimes hold 1500 for a good 30-60 seconds. If I turn the AC off when it's doing this (idling at 1500), the idle will immediately drop back down to where it's supposed to be.
Is this normal? The fact that it's random is what concerns me.
Thanks in advance. Hope that I explained it well enough to make sense.
Old 06-17-2007, 02:29 PM
blownta00's Avatar
that happens sometimes because the a/c compresser turns on so the engine needs those extra rpms to run it. thats way you lose gas mileage when the a/cs on.
Old 06-17-2007, 02:46 PM
Grimery's Avatar
Alrighty sounds like it's nothing to worry about.
I wasn't worried when it would idle around 1k with the AC, but the random 1500 idling with the AC on was concerning me.
Much appreciated.
