what can I do to get more out of my H/C combo??
Old 06-18-2007, 06:38 PM
bluehawk2's Avatar
Default what can I do to get more out of my H/C combo??
I have Patriot CNC'd 243 castings with stock valves. I am running a 232/236 595/601 +4 on a 112 Comp XER lobe. I am wondering what i can do to get a little more out of my combo. I am going to stick with the cam I have.
I don't want to have to fly cut the pistons. I am wondering what my options are. I have thought about pulling the heads and have them hand ported. I have also thought about getting bigger valves and/or getting the heads milled. I just don't know what I can do with out fly cutting the pistons. I really don't know if I would have issues with PVC with the bigger valves and/or milling.
Give me some suggestions. Any help would be appreciated.
Thanks
Old 06-18-2007, 06:55 PM
purdueranger's Avatar
port the heads, have it milled a little, Fast 90/90 intake ported, NW 90mm T/B
Old 06-18-2007, 07:02 PM
Louie83's Avatar
I agree.
Milled and a port matched 90/90 will make a big difference.
Old 06-18-2007, 07:06 PM
transamfreak01's Avatar
+ on that... it will wake the car up nicely
Old 06-18-2007, 07:27 PM
ChrisUlrich's Avatar
Thanks
What you makin on that? Or what you runnin?
Old 06-18-2007, 07:28 PM
bluehawk2's Avatar
I didn't really have a 90/90 in the budget for right now. I was thinking more along the line of milling and maybe larger valves with a good hand porting job.
Are any of you running milled 243's(maybe with the larger valves) with a cam like mine?
Old 06-18-2007, 07:36 PM
bluehawk2's Avatar
With cam only I made 403HP and 385 Torque on a dynojet. I don't know what I am making now with the 243's.
Old 06-18-2007, 08:52 PM
DaveX's Avatar
What are your scr and dcr numbers? Also, with that cam advanced that far your valve events are likely costing you some torque in the midrange and will also be flat on top.
