bout to order valves, but which ones?
I've been using Ferreas and they've lasted pretty good so far. If your comparing after market valves to stock, be aware how much Piston to Valve Clearance they eat up. The margin (thickness of the part that hangs down into the piston) of aftermarket valves is much thicker. I didn't realize this when I put Ferrea valves in my heads. You should be fine unless your running a high 230's cam and decent milling. If I could have done it all over again, I would have kept stock valves because you don't gain much from going from a 2.00 to 2.02 and my PTVC sucked.
Yes they make the stock valve lengths as well as longer ones as well. http://www.ferrea.com/catalog/2006Domestic.pdf Go to the end of page 38 and the first part of page 39.
