11 Second Club Snake eyes are a good thing
Going for 11's Cam only w/ 224/224!!! Who's done it?!?!
Old 06-24-2007, 03:57 PM
1fastz's Avatar
Default Going for 11's Cam only w/ 224/224!!! Who's done it?!?!
well im on a quest for 11's and i need some insight. It seems as though its rare to hit 11's with just bolt-ons and a 224/224 but im going to make a mission of it!! With just a lid and exhuast and nittos i did 13.2@108 2.0 60'.... and then Last year i went to the track when i had:
SLP Lid/MAF/induction set up
LongTubes w/ X-pipe
3200 stall
224/224 112lsa
Drag radials
UNTUNED!!!
Went from a 13.2@108 To a 12.4@109 w/ 1.71 60'
I went to the track the same week i just finished installing these mods so i never had a chance to tune it after my cam/long tubes but i still went to the track.. i said "screw it, its only 15 min from my house." Unfortunatly i should have got it tuned right away. The car was banging off the rev limiter before it would shift and it was a dog after the luanch.
New setup:
LongTubes w/ H-pipe
3500-3800 TCI stall w/tranny cooler
224/224 114lsa
Ls6 Manifold
Bo Ported/polish TB
Tuned by a pro w/ HP tuners
M/T Drag radials
You think i can knock off .4 after getting it tuned and adding a bigger stall,better drags,ls6 manifold and ported TB and be a 11 SEC CAM ONLY 224/224??
Old 06-24-2007, 04:53 PM
Havok2's Avatar
yupvery possible
i did 12.1 bolt ons so im pretty sure a cam would net me an 11
Old 06-24-2007, 05:02 PM
Bowtieman4life's Avatar
I went 12.001 at 117.7 w/ cam, bolt ons and 4.11 gears. Weak 60 ft and clutch Master cylinder issues making 2 to 3 shift time consuming. (1.84 60ft) 275 lbs driver (me) Never went back but had 11's in it. check sig
Old 06-24-2007, 08:51 PM
SPRAYED 01's Avatar
i went 12.0 with tr224 cam only with 411 gears,all bolt ons with slicks.
Very possible.
Old 06-24-2007, 09:10 PM
cainsw's Avatar
11.29@121 with my TR224 cam.
Old 06-24-2007, 09:30 PM
SPRAYED 01's Avatar
cainsw, what does you car weigh?
Old 06-24-2007, 10:17 PM
cainsw's Avatar
about 3375 with me in it. But it did run a best of 11.60@119 at full weight (3505#'s) in 1275ft alt. The 11.29 run was at 950ft alt
Old 06-24-2007, 10:52 PM
1fastz's Avatar
^^^^ DAMN!!! What exactly did you drop off to weigh that much!?!? thats what im talking about!!! i was just wanting high 11's possibly mid, but 11.2!!! very nice
Old 06-25-2007, 12:25 AM
slmdLS1's Avatar
"sstony" did 11.97 @ 116 with stock heads, bolt ons, and the 224 cam.
Old 06-25-2007, 12:32 AM
LS1iFiEd's Avatar
My car went 11.67 @ 116 with a similar cam 224/220 MTI Stealth Cam Full weight,Fully loaded car.So Its def. Do-Able
Old 06-25-2007, 09:57 AM
Mac 2002 SS's Avatar
i'm in the same boat you are 1fastz. i just ordered a TSP 224 XE .566 115 cam for my SS. I ran a best of 12.21 awhile back full weight . my car normally averges 12.4's and high 12.3's during this time of the year full weight. i'm hoping with this cam i can run 11.8's or better full weight. i will add some other weight saving parts later on in the year like skinnies, k-member ,& lt. weight battery.
good luck
Old 06-25-2007, 11:51 AM
1fastz's Avatar
im pretty confident i can do 11's, but i know if i do, ill have the urge for 10's after that lol....... and thats why i bought a nitrous kit!!! 125 shot should do the job
Old 06-25-2007, 02:24 PM
RUSTYTA's Avatar
do u have a set of gears??!! gears and id say ur at high 11s...
Old 06-25-2007, 09:08 PM
cainsw's Avatar
That is what happened to me. But instead of nitrous I want to do it NA. This is why I started removing weight. I removed the seats, carpet and AC compressor (didn't work anymore and I hardly ever drive it on the street anymore) after I get to the 10's NA I will put it back together. Oh, it helps that my car was a stripper anyways. No options except hurst shifter and cd player.
I plan to swap the 4.11's for 4.56's and a 28" et street
Old 07-06-2007, 01:18 AM
Omega Doom's Avatar
you will hit 11's! I predict a 11.6@116 !!!!
Old 07-06-2007, 02:43 AM
Jersey_TA's Avatar
If you mount up a set of weld draglite rims or prostars you're going to drop .2 off your time. I went 12.088 @ 115 with just bolt-ons and the STOCK convertor on Weld draglites. My race weight was 3450. My friend with a stripper Z28 went 11.8 with bolt-ons and a 3600 stall, skinnies, and DRs. Trust me, go when it's around 50 degrees and on skinnies and some nice DRs and you should be there with a monkey driving the car. It's not as hard as you think.
Quick Reply: Going for 11's Cam only w/ 224/224!!! Who's done it?!?!
