amp question?? (search is f-ed up)
im trying to find out what amp would be good for my setup without breaking the wallet..
i have 2 10" alpine type-E's in 2 stealth boxes (ds and ps).. what amp would be good for this setup.. i dont know **** about car stereos lol.. i can install them but matching **** up is a diffrent story..
im gonna purchase better subs in the future, but dont know when
will that amp work with 2 subs?? im not 100% sure what "monoblock" is im guessing it only has one channel.?.? i dunno
im new to sound systems
EDIT: i may be buying some ALPINE SWR-1042D subs.. 500rms 1500peak.. how do these sound?? im looking for more quality then boom.. but i still want some boom
You have a pair of Alpine Type E subs? Wired up to a monoblock in parallel configuration will get you to a 2ohm-mono load. I don't know much about Kicker amps, but I've always like the JBL GTO amps. They put out full power at 2ohm and can generally be found cheap on eBay, www.sounddomain.com among other sites.
ya i have some old type type E's but i might get some 1500w type R's..
i also like MMATS subs and amps but i harder to come across
i also have some MA audio subs that i won on ebay a few months back for 2bucks (i think it was 2 bucks lol)
that wiring diagram seems pretty simple, what about wiring them up in series?? or would i not wanna do that??
you are def gonna need a mono amp. if it was me i would purchase an amp that puts out about 400-500watts at 2 ohms but is stable at 1 ohm. The power output at one ohm will be significantly greater than that @ 2 ohms. and would prevent you from needing to buy a larger amp when you go with the type r's. you would need the dual 4 ohm speakers and wire them in a parallel which gives you a 1 ohm mono load. Personally I would check out the memphis 1000 watt mono amp. its gonna run you about 400-450 but is an excellent sub amp choice.
Hate to burst your bubble, but looking for an amp that does a 1ohm load isn't always going to result in more power. There are plenty of amps that put out full power at 4ohm, and 2ohm. Each of them also have more power than some of the amps that put out full power at 1ohm.
If the original thread starter wanted a pair of Type R's and already had an amp that did full power @ 2ohm mono all he (or she) would need to do is just buy a pair of 2ohm DVC (dual voicecoil) subs.
That image would give you a final load of 2ohm-mono, which would be perfect for the same 2ohm-mono amp he would have for the pair of Alpine Type-E's that he (or she) already owns.
so lets say i bought these
http://cgi.ebay.com/2-SWR-1022D-ALPI...QQcmdZViewItem
and i also bought this
http://cgi.ebay.com/ALPINE-MRP-M850-...QQcmdZViewItem
and wired it up like this..
would that be a pretty good?
or should i find an amp with slightly more power..
im looking to spend under 500 on the amp and both subs... im just gonna sell my old type E's and start off fresh
i like alpine.. ive had my alpine cva-1006 flip out screen for ages, and its been been to hell and back and has held up great.. i know thier stuff is quality, but im not stuck on them.. if i came across a good deal on another quality brand i wouldnt mind getting that instead..
