LSX pics and info. must read if your doing lsx.
8 second mod
i have some pics and ifo for people to help save some time and agrivation.
first off everything is all set on my setup. the machine shop did a great job.
issues i found tho.
1. i was missing one pipe plug for the rear (had one at my house)
2.the bolts they sent me for the lifter retainers where to short.(went to home depot and got ones 1/4" longer and done)
3. the cam plate gasket was pain in the *****!!!!
4. the suplied bolts for the cam plate stuck out to far, and hit my timming chain. (4 of them required fileing them down to clear, easy fix but needs to be adressed)
other then that, so far so good. my damn timming chain was loose as could be so i overnighted a new double roller so i will have the motor done tonight, and probably set in the car.
tommorow i will get the tranny in and exhaust made and saturday i should be able to fire it up
issues i found tho.
Originally Posted by Black2001z06
Corona Light always makes everything look better though!
Engine looks like it's gonna be a hoss!
8 second mod
thanks again guys.
we are working on the tune, looking at a SD tune. we'll see.
last nights progress was good!! i was out till 2:30 messin around.
motor is in, intake on, valve covers on, water pump ect ect. tranny is in, converter bolted up, drive shaft in, headers in 99% of the wires back together.
im close, once im out of work, im going right home get the alt in, radiator, finish up my fuel system, rig up a t-cable, and start welding the exhaust up.
possably fire it up tonight.
man im sleepy
man im sleepy
