car idles high on initial start up.?
Old 06-28-2007, 03:39 PM
yellowbird's Avatar
Unhappy car idles high on initial start up.?
can anyone give me some guidiance on what might be going on with my idling problem,seems as when i leave my car sit a few days[cold]and go an start it up,it wants to shoot up to around 16-1700 rpms and then start to decline down to around 900. car is a 2002 t.a after market t.b. cam, headers.stall. mods where done a couple of years ago,but the idling issue started this spring. p.s, over the winter i had a battery tender on all winter.anything i can do or look for.? what about turning down the idle screw.?
Old 06-28-2007, 05:18 PM
1320 killer's Avatar
sounds like you have a slight leak. I would check around the intake manifold
Old 06-28-2007, 05:22 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
check EGR gasket.
Old 06-28-2007, 07:22 PM
99NMB's Avatar
if its idleing high then dropping back to normal, i would figure it would be a cold start thing right???
Old 06-29-2007, 06:12 AM
Fb0dy0nly's Avatar
yeah, most engines do this in order to heat things up quicker. It is normal for the engine to idle on start up a bit higher than it does after it is warmed up, especially in the winter but at the same time, 1700rpms is pretty high. When I start mine up in the morning, it will stay around 1000-1100rpms for a minute or two, then drop to normal idle.
Old 06-29-2007, 06:24 AM
Jon5212's Avatar
^^^+1 I was going to say the same thing, pretty much the "choke" feature when the car is cold. Every car i've owned when I first start it idle goes up to ~1500-1600 rpm.
Old 06-29-2007, 07:58 AM
2_wacko's Avatar
My 02 z28 has done this since day 1.
Old 06-29-2007, 10:59 AM
LS1>girlfriend's Avatar
your engine is choking itself...like you do to a lawn mower when it doesnt start on the first pull.
Old 06-29-2007, 02:34 PM
yellowbird's Avatar
anyone know how I can get that initial rpms down to around 1200 rpms when it first starts up.?
Old 06-29-2007, 07:59 PM
have a tuner change the choke settings.
Old 07-02-2007, 08:59 AM
Jon5212's Avatar
Why does it matter? If the idle returns to normal after warm up what is the big deal?
Quick Reply: car idles high on initial start up.?
