brand new 85mm MAF's for cheap on ebay...found this in our conver. & hybrids section.
Old 07-01-2007, 06:06 PM
deeloc1's Avatar
Default Nnew 85mm MAF's for cheap on ebay...found this in conver/hybrids-5150mechanic's post
https://ls1tech.com/forums/removed-locked-thread-graveyard/741300-gm-85mm-maf-if-anybody-needs-one.html $35.99!!
deeloc1 is offline
Old 07-01-2007, 06:26 PM
snake charmer's Avatar
good looking out ! i think a harness has to be bought to make this work on our cars but is not big deal . around 20 bucks i think .
snake charmer is offline
Old 07-01-2007, 07:04 PM
jimmypop13's Avatar
you'll have to find out if it has a built in IAT sensor. The corvette 85mm sensors do and that's why you need the 3-5 wire harness. These may still need that harness, just the IAT half of the harness isn't used.
It's a great deal either way!
jimmypop13 is offline
Old 07-01-2007, 10:25 PM
deeloc1's Avatar
On ebay it goes into detail about the applications that it can be used on and it does say the Vette. So i guess you do need the harness. but hell a 85mm for 60bucks...can't beat that! does anyone know where i can get the harness from so i can make it compatable with my 02 SScamaro Ls1 for my swap?
deeloc1 is offline
Old 07-01-2007, 10:36 PM
5150mechanic's Avatar
I bought one and passed down the info. The part number is a good one if searched thru ls1tech for upgrades.
5150mechanic is offline
Old 07-02-2007, 06:00 AM
sciff5's Avatar
+1 would like to know where the harness can be found myself as well
sciff5 is offline
Old 07-02-2007, 10:13 AM
Thule's Avatar
where can i find the harness? i think i will buy one of those mafs,
Thule is offline
Old 07-02-2007, 10:33 AM
14 Second Truck Club
mzoomora's Avatar
Casper's Electronics makes the harness. You can get it from most sponsors- Speed Inc, Texas Speed, etc.
mzoomora is offline
Old 07-02-2007, 10:38 AM
mzoomora's Avatar
https://www.casperselectronics.com/M...ry_Code=camaro
mzoomora is offline
Old 07-02-2007, 11:39 AM
Thule's Avatar
bougth it thanks for the link
Thule is offline
Old 07-02-2007, 02:54 PM
ssgunny's Avatar
So I would guess this is simular to the SLP version that costs almost $200 minus the cable? I guess this brings up the question is it really needed if you are not planning to build a motor capable of greater than 500hp. My reading on this forum indicates that the stock MAF is adequate under 500hp. I guess for under a $100 (cable and MAF) it would be enough of an incentive just to get no matter what you plan on investing in the motor.
Also the description for the cable says it is needed for use on a LT1. Would this be needed for camaro's equiped with the LS1 or is it a different cable that is needed?
ssgunny is offline
Old 07-02-2007, 03:19 PM
Thule's Avatar
yeah i was thinkin about that it said lt1, but o well.. i will just have to see,
i got 90mm tb/intake, so i thougth the oem was a little.. to small, so i think this one will be fine,
at least, if it works, i am glad, for that price, under 100 bucks for both, with taxes
Thule is offline
Old 07-02-2007, 03:31 PM
ssgunny's Avatar
I guess the easiest way to confirm is to look at the connection at the MAF and see if it has 3 or 5 wires. My car is under a car cover in the garage so will check when I get a minute.
ssgunny is offline
Old 07-02-2007, 03:32 PM
Yahelou's Avatar
keep us updated on if it works or not and the gains from it
Yahelou is offline
Old 07-02-2007, 04:39 PM
ssgunny's Avatar
I see three wires from the harness going to the MAF on mine so I guess that the cable is for LT1 or LS1.
Further I called and talked to Justin @ Casper Electronics and all of the LT1/LS1's found in Fbody's have the 3 wires that come from the harness. The larger 85mm MAF (found in LS1 vettes 97-04 but I am not sure of the LS6) requires the 5 wire plug so you need the adapter.
ssgunny is offline
Old 07-02-2007, 07:18 PM
Thule's Avatar
yeah i could try to plug both and check if there is any diffirent, my car will hopfully be running in a month or so
Thule is offline
Old 07-02-2007, 08:39 PM
wannafbody's Avatar
you probably could get the adapter from Pace performance parts
wannafbody is offline
Old 07-02-2007, 08:47 PM
ssgunny's Avatar
Seeing your signature it looks like you may benefit from the larger MAF although its benefit will, I feel, will only be noticed on a dyno.
ssgunny is offline
Old 07-02-2007, 08:55 PM
Thule's Avatar
yes i think that make senses, or maybe i will never know.. living almoast at the north pole it will bea a disaster to tune it rigth with those modds, so i will never know how much i can get
Thule is offline
Old 07-03-2007, 12:01 AM
mzoomora's Avatar
The harness will work, I have used them before on F bodies.
mzoomora is offline
Quick Reply: brand new 85mm MAF's for cheap on ebay...found this in our conver. & hybrids section.
