What cam to support 550+rwhp on a stroker?
What cam to support 550+rwhp on a 414 stroker? I am having Ron at Veng Racing port my Fast and port match it to the TFS 235cc heads. I was thinking of also changing my cam .I want a proven cam. My current cam is 244/248..612/615..112LSA. Should I go bigger or just see what the intake does? I dont want to change to much at one time but I want power. Driveability is not a issue. My comp. is 11.8 and I have all bolt ons. I already talk to Ron about a cam but I want to see what everybody else thinks.
more aggressive lobes may help do the trick... switch from the XER to LSK lobes and with those valves shooting open faster you will gain power. also it looks like you are running a proven middle range driveability cam for a 402/408, and a fairly aggressive cam for a 346...... almost the same cam MellowYellow is running in his 346.....so I suggest adding 10 degrees of duration and looking at getting the perfect advance and grind for those heads while you are at it.
Take Ron's suggestion..... also shoot Patrick G $25.00 via paypal for his input.... give him your bore, stroke, boltons and goals and he will give you your current timing events along with the difference in his suggestion. well worth the money! He is awesome.
Good luck bro..... you will still get drug by me..... I aint running you from that 65mph supra ****... it is gay. 20/30 roll for me!
Feel good about those heads man..... making the same power with 1.5 points less compression is a good thing. Who the hell would build a damn near 13:1 compression streetcar for texas heat and pumpgas to begin with?
LS1 Tech Administrator
You're going to get really close to 550 rwhp with the cam you have if the porting is done right. For a guarantee above 550, you could add 4-6 degrees to what you have.
250/254 .612/.595 112LSA +2
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
grind it straight up and degree the cam for the correct you are looking for.
xfi lobes are nice as well. you should consult an engine builder not a shop that just throws out cams. 99% of them call up a cam grinder and the techs at the cam companies are hit are miss with what you need.
Originally Posted by WOTFMAN
advancing the cam off the centerline is not the best way to make power...
Vengeance has done a lot R&D on cam profiles for LS stoker motors..they are not guessing and their results have proven that they know what they are talking about..
Originally Posted by Brian Tooley
If you want a proven cam then call someone with proven cams, like Vengeance...and don't even think about running LSK lobes, after they beat Patick G's parts to death I don't think he likes them anymore either....
btw: XER here.
Your running cathedral port heads. If you make 550hp its going to be very far down the RPM band a 414ci. You should switch gears and run ls7 setup. It'll make more RPM and alot more power for the $$$
Im running a 259/267 @50 in my Mecham on a 115 LSA and great street manors. I think the tuner is the bigger issue with drivability... I could hardly drive my car with the much smaller G5X3 and and the tune from LG. After the larger cam was installed a good tune was done by a local shop and the car has great street manors. Im also looking into a Beck intake, I think the Fast 90 has become a restriction at this point.
550 is weak for a street stroker setup. All i see is dyno numbers...Who gives a rats *** about that. The track is what counts and ive yet to see anything that impressed me there.
Oooops I misssed the whole point of this thread..I thought we were discussing a camshaft application in a 414 cu. in. stroker motor....when in reality we were supposed to be impressing you.. .. if you don't have anything positive to contribute please spare us the BS from whogivesaratsass.com ..
