Cutout before catalytic converter
i have an 1999 ls1 camaro and the exhaust is pretty bad i was wondering if i should get a cutout before the cat under the passenger seat? It allready has the simulators for the back o2 censors ready to be hooked up. Would i loose too much back pressure and actually loose power or should i just buy a new exhaust kit and eliminate the second cat?
i dont know if you would loose power or not or if it would be enough back pressure. i am thinking it would be fine. i know it can be done and has been done lots of times as long as u have the o2 sims or tune it out, otherwise the light will come on
