TR230/224 and PRC LS6 CNC heads
Old 07-10-2007, 06:32 PM
bww3588's Avatar
Default TR230/224 and PRC LS6 CNC heads
230/224 .575/.563 111 LSA
PRC LS6 CNC Ported Heads
this cam caught my eye, because with bolt ons and an LS6 intake, stock heads on a 99 it made 410 RWHP and 389 RWTQ. i was hoping with a good tune i should be looking at around 460/430 at the wheels, and a mid 11sec pass. what do you all think? i was also throwing around the idea of getting a FAST 90/NW90 setup, and hoping for another 15 hp/tq? any personal thoughts on this one? its not going to be DD'ed but it will be driven to shows and i want it to be streetable to a point.
Old 07-10-2007, 06:45 PM
gillbot's Avatar
with stock heads and mac headers, I ran the time and made the #'s below, info is here: https://ls1tech.com/forums/dynamometer-results-comparisons/476349-tr230-224-a4-dyno.html
Old 07-11-2007, 12:00 AM
PREDATOR-Z's Avatar
Good combo, mill the heads a little .015
Old 07-11-2007, 01:10 AM
bww3588's Avatar
this is really just a "somthing to hope for" because im a broke college kid. but gillbot, if you dont mind, id like to meet up sometime and give your car a look see, hear it and what not. just to get a feel for what its all about and what to expect.
Old 07-11-2007, 01:24 AM
GMmexican's Avatar
tr 230/224 111lsa......im hoping to get this cam also, how would it be on a dd bolt on car with stock heads?
sorry for the hijack
Old 07-11-2007, 01:31 AM
PREDATOR-Z's Avatar
Look in dyno section for graphs and results.
A reverse split with tight LSA on stock heads yields very good results.
Old 07-11-2007, 03:51 PM
gillbot's Avatar
Sure, I can be reached anytime on daytonfbody. I'm usually around all weekend and later in the day on weekdays.
See my thread above. My car's heads are stock, never been removed. The only change to them was the valve springs to support the tr230/224 cam.
Old 07-11-2007, 04:40 PM
BayAreaSS's Avatar
I need to research this cam. It looks to be a good performer
Old 07-11-2007, 04:54 PM
bww3588's Avatar
im suprised more people dont have it since its such a good cam only cam. let me ask this, if i go with the PRC LS6's and have them milled .015, will i need to flycut?
Old 07-11-2007, 05:07 PM
gillbot's Avatar
I was gonna go with the 5.3's over the LS6's myself based on someone's recommendation but now I don't recall who told me that and why!
Old 07-11-2007, 05:23 PM
bww3588's Avatar
probably the same reason i was too. smaller combustion chamber and still CNC ported, for about the same price. TEA has them. however, i have heard that with any cam over 228 duration, flycutting is almost required and you would be stupid if you didnt, could be different with different cams tho. and ive heard that anything at 230 or above requires flycutting. thats why i started looking at the PRC LS6's milled .015. this will net about a 10.8-11.0 CR (depending on head gasket thickness) and still pass without flycutting. please correct me if im wrong, just gathered information.
Old 07-11-2007, 05:25 PM
gillbot's Avatar
I believe I asked thunder and they said no problem with the 5.3's and the TR230. Maybe someone from TR can chime in and answer this?
Old 07-11-2007, 05:27 PM
bww3588's Avatar
really? if this is the case, ill be looking at the CNC 5.3's
Old 07-11-2007, 05:36 PM
phoenix1987's Avatar
I have this cam and love it! I am thinking about going with PRC (Texas Speed) 5.3L stage 2 heads.
Old 07-11-2007, 08:05 PM
gillbot's Avatar
I checked with TR and they said verify P to V. I know someone told me it was fine but yeah, it should probably be checked to be safe.
Old 07-11-2007, 11:06 PM
bww3588's Avatar
i guess ill get the old modeling clay out......
Old 07-12-2007, 12:07 PM
LS1TECH Sponsor
badpewter-z's Avatar
i loved my tr230 when i was cam only , drove great , ran great and produced good times at the track . great idle sound and pulled hard from 2500rpm .
one suggestion i will make though is to get gears with it to make the driveability even better
Old 07-12-2007, 02:32 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Our 5.3l heads, Street LS6, and 2.5 LS6 will all clear fine with the 230/224 camshaft. We've sold cylinder heads for those camshafts many times with some great results!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-12-2007, 02:48 PM
Serial Thriller's Avatar
I may be off base here, but since the 230/224 seems to be intended for cam-only cars, maybe you should look into some other cams to go with the ported heads you get. I'm sure you will make great power with that setup, but there may be a more optimized cam for your heads' flow characteristics.
Old 07-12-2007, 03:01 PM
Websy21's Avatar
I agree
Quick Reply: TR230/224 and PRC LS6 CNC heads
