tsp lid compared to slp
Old 05-12-2003, 07:10 PM
chevy1322's Avatar
Default tsp lid compared to slp
anyone out there with a texas speed and performance airbox lid? how does it compare to slp airbox lid?thanks
Old 05-13-2003, 09:05 AM
SSCamaro99_3's Avatar
Default Re: tsp lid compared to slp
It should perform better than any of the other conventional lids.
Old 05-13-2003, 11:25 AM
LOnSLO's Avatar
I had an SLP lid before. It didn't fit worth anything, and also had hood clearance problems (SS). Put the TSP lid last week, and fit is absolutely perfect, and it doesn't bang my hood. I got the TSP just for the fit, but I'm sure there's a little to gain with it powerwise.
Old 05-13-2003, 11:53 AM
Fast Eddie's 02 T/A vert.'s Avatar
I went with the SLP Lid because i was able to use my factory hose and keep it looking factory.I don't understand how the breather filter works for many of the other lids.
Old 05-13-2003, 06:55 PM
Administrator
unit213's Avatar
Fast Eddie- You just stuff a filter into the AIR hose with most aftermarket lids.
Old 05-13-2003, 08:47 PM
GeorgeC's Avatar
My TSP lid fits better than any other I've had or seen!
Old 05-13-2003, 08:52 PM
smash's Avatar
You didn't say if you had an SLP and were looking to switch, or if you were debating SLP vs. TSP. So, that said. I have an SLP in my '02 TA. It fits just fine and I dyno'd at 310rwhp (stock+lid), so it seems to work!
I've got no experience with the TSP. Good luck either way.
Old 05-13-2003, 10:52 PM
bigeller's Avatar
I may be getting a smoked lid.. I know my MTI clear lid fit like crap.
Old 05-14-2003, 09:47 AM
LAST ONE's Avatar
SLP OE lid is a much higher quality lid vs the Performance Parts SLP lid, Installed the OE lid and there was a sop performance increase and fit very well doesn't rub on hood.
Old 05-14-2003, 11:02 AM
Thanks for the info.Unit213,
That's all there is to it???I thought you had to buy hoses and fittings and so on.
Old 05-14-2003, 01:10 PM
Fulton 1's Avatar
Eddie,
That's right. If you're replacing the stock-type lid with an aftermarket unit that doesn't have the hose attachment, all you have to do is unplug the AIR hose from the old lid and clamp the little breather filter onto the hose. Most people also shorten the hose and tuck the filter off to the side to get it out of the way.
The main concern is that you are not pulling unfiltered air into the AIR hose. It should either pass through the panel filter (like the stock and SLP lids) or have its own little filter like most all aftermarket lids.
Old 05-14-2003, 08:00 PM
Last Yellow Bird's Avatar
I have an 02 T/A WS.6 and I dynoed 325 rwhp with only an SLP lid and K&N filter. I may have a strong car, but I also feel the lid helped a lot.
I would think of changing if I thought the TSP lid would give me even more.
Just my .02
Old 05-14-2003, 08:22 PM
unstable Vic's Avatar
slp lid here, fits like a glove!!!
Old 05-14-2003, 10:22 PM
Camaro SS 2002's Avatar
100% agreed!
Old 05-14-2003, 10:31 PM
Trans_AmGuy's Avatar
I've got an SLP lid. No complaints here!!
Old 05-15-2003, 02:27 PM
LOnSLO's Avatar
The OEM lid from SLP is almost as bad as the stock Z28 lid. It sucks, although it fits like a dream. I did a little track comparison this past winter between the OE SLP lid, and the aftermarket SLP lid. I picked up just over two tenths on average, using the aftermarket lid.
Old 05-15-2003, 03:07 PM
Koncrete's Avatar
just finished putting lid and coldair intake on mine. I can tell a difference, only one question though.
I didnt have an airtube on mine is that ok? I have a 99 t/a
Old 05-15-2003, 04:08 PM
DONAIMIAN's Avatar
Its fine, the only ones that need em are the 00+ cars
Old 05-17-2003, 06:34 PM
WS6 GreeN's Avatar
I love my SLP lid, have had no problems.
