Shifting into 3rd?
Old 07-11-2007, 10:59 AM
ckyconan2003's Avatar
Default Shifting into 3rd?
Anyone else have issues sometimes getting thrid in gear when you run on the track or run on the street? I can slam all the gears fine but sometimes third just doesnt want to go in. Is this common, or do i just need to concentrate more?
Old 07-11-2007, 11:30 AM
Arctic2002ss's Avatar
Yes, the 2-3 shift is the hardest. I have much less trouble since I changed the shifter.
Old 07-11-2007, 11:56 AM
lt197formula's Avatar
I used to have trouble with the stock shifter, once I bought a Pro 5.0 with a cut Lou's short stick it feels perfect slamming into 3rd.
Old 07-11-2007, 11:57 AM
-PEPE-'s Avatar
Mine was doing that before the new setup, turned out to be the syncros were worn bad. Joe @T56 Rebuilds did his majic and it's one of the smoothest shifting trannies I've ever raced.
Old 07-11-2007, 12:30 PM
98 TA's Avatar
The 2-3 shift is always the hardest, but can be much worse if the syncs are worn. It can make you look like a rookie racer.
Old 07-11-2007, 12:47 PM
01FormulaTA's Avatar
you need the drill mod
Old 07-11-2007, 12:48 PM
go to www.installuniversity.com and that will fix your problem
Old 07-11-2007, 12:58 PM
95LT1963's Avatar
what is the drill mod
Old 07-11-2007, 04:20 PM
http://www.installuniversity.com/ins...r_cylinder.htm , here it is but actually I just realized you guys have LT1 cars so I dont think you guys can do this except maybe the '97's......
Old 07-11-2007, 08:46 PM
98 TA's Avatar
The drill mod is more of a fix for the pedal sticking, not necessarily for hard 3rd gear shifts. The factory hole is very small, thus being restrictive.
