Car misses under acceleration
Old 07-12-2007, 07:36 PM
V8RX7FTW's Avatar
Default Car misses under acceleration
Problem is when the motor goes into load in 3rd gear and up it seems to miss and pops can be heard from the exhaust. Its a 2001 ls1 with new ngk plugs gapped at .055. Wires are a set of crane fire wires. Only mods to the engine are intake and long tube headers with dual 3 inch exhaust. Motor is swapped in a 93 rx-7. I'm thinking its a ground issue but i'm open to opinions and other things to check.
Old 07-12-2007, 10:01 PM
V8RX7FTW's Avatar
if it helps any this occurs only under wot and sounds like popcorn through the exhaust
Old 07-12-2007, 10:06 PM
Sharpe's Avatar
Mine was front O2's were out. im sure that would throw codes though...
Old 07-12-2007, 10:35 PM
V8RX7FTW's Avatar
i was hoping it would throw a code but nothing is up code wise.
Old 07-13-2007, 12:03 AM
Sunset'01Z's Avatar
sounds like detonation to me. are you running 93 octane?
Old 07-13-2007, 05:06 AM
V8RX7FTW's Avatar
i was wondering the same thing. I put 93 in it but maybe I got shitty gas.
Old 07-13-2007, 09:48 AM
1FSTLS1's Avatar
Had a similar problem long time ago and the headers melted some wires and they got shorted only under hard acceleration.
Old 07-13-2007, 02:37 PM
Blacked Out's Avatar
Yeah I would check your KR.
Old 07-22-2007, 07:09 PM
98SS1LWEE's Avatar
any pdates? You find the problem yet?
Old 10-25-2007, 05:25 PM
zmonsterjb's Avatar
ttt tt
Old 10-25-2007, 07:41 PM
edcmat-l1's Avatar
Secondary ignition miss. Cracked plug, plug wire not snapped on all the way, etc.
Old 10-26-2007, 08:35 AM
pphilli1's Avatar
Check 02 sensor wires-seen long tubes touch/melt wires & throw no codes
but cause vehicle to run rich under acceleration,causing popping
You can also pull the plugs from 1 side to see if they are black,if so
the 02 connection could be the problem on that bank-also check the
02 sensor to see if they are black-if so they are bad-they should be brown/
rusty color-same with plugs-I run NGK TR55 @ .043
That has worked for me.
Old 10-27-2007, 09:53 PM
zmonsterjb's Avatar
I figured mine out, car threw a p00336 code and turned out to be a bad crank sensor.
I regapped old plugs to .40(ngk) and added some nos booster to the 93 octane. Took it for a run and still got a ping. Redouced timing in that area and its all gone for now.
