flip a switch to a different tune
yes you can do that. You can wire in a potentiometer and when you hit the switch the PCM will pull a few degrees of timing.
I think EFILive has a OS that can pull timing for nitrous also.
Originally Posted by Eurospec2
EFI LIve COS-5 pulls timing and adds fuel at the flip of a switch!
You don't need a special OS.... A resistor can be used with a relay to force the IAT's input into an unused area; this will allow changes to both timing and fueling (via PE modifier) that are active only when armed.
Tuning for a "dry" or MAF related/compensated shot of N20 does not require anything other than a spot on MAF tune. You will be limited on how big of a shot that the MAF can compensate for. Typically most consider the 150 shot, the max for the dry shot.
With proper safety equipment the "Wet" shot will support a bigger hit for sure.
The EFI Live Custom OS, which is free, can pull timing and add fuel independent of the MAF or IAT settings-which, in order to get max motor performance should be left alone(besides an adj pot with the IAT).
You can pull timing by flanagling the IAT settings with a switch or pot.
For the OP, what are your overall goals for the car? What mods do you currently have? What do you expect/need the N20 to do?
ok i'm about to be running a f14 with 5.3 prc heads... electric water pump, long tubes, ls6 manifold, under drive pulley, every single bolt on possible except a 90/90 i'm trying to get above 550 with a 125 dry hit... is this possible? or should i say forget it and go wet?
EQ ratio is Stoich / target AFR ....... 14.628(stoich) / 12.8 (desired AFR) = EQ of 1.143.
Once your VE/MAF are calibrated you will hit your target EQ
BUT the key word is "calibrated" how many peeps have their VE/MAF calibrated???
Originally Posted by VH5150
cool, good ****...
Pretty much anyone with HPT, EFI Live or other software that logs and allows access to change the tables can calibrate their MAF and VE tables. Its the basis of learning tuning.
cool, good ****...
Originally Posted by Beer99C5
My MAF and VE is dialed in.
yup
