Bore a 5.3L block?
Old 07-15-2007, 08:50 AM
N4cer's Avatar
Default Bore a 5.3L block?
How far can the 5.3L iron block be bored?
And the aluminum block? <-- I believe that one can just be bored to a 5.7L.
Any help would be greatly appreciated folks.
Old 07-15-2007, 09:06 AM
nobreaks254's Avatar
I know you can bore the iron block out to stock LS1 size. Dont know if you can go larger, not sure about the aluminum block either. I would guess you can only hone the cylinders like the LS1 motors.
Old 07-15-2007, 09:09 AM
N4cer's Avatar
Yeah I figured that on the aluminum. But for the iron, I wonder if it can be bored to 4.030"? 408 with a stroker crank.
Old 07-15-2007, 10:12 AM
sroach20's Avatar
aluminum can go to 3.9 but the 4.0 is for a 6.0 iron, not a 5.3 iron.
