HP Tuners SD Tune - HELP Please!
Old 07-24-2007, 09:34 AM
SonofaBish's Avatar
Default HP Tuners SD Tune - HELP Please!
My car is gonig to be fired up very soon. The only problem is for some reason the Aeromotive Fuel rails don't seem to be seating to the o-rings, so they're spraying fuel everywhere...
however, the guy building my car is looking on the HP tuners repository for a tune that will work well, and isnt' having much luck fiding a full SD tune... can anyone help me out and send one to me, or give me some info on how to identify ur tune in the repository...
looking for... full SD tune... .9bar, 60lb injectors, 220/224 114 or 115 cam (cna't remember)
just need something to get the car running with and break in with ... it will go to the dyno to get tuned ASAP, but i need somethign to get it going with... any Help is greatly appreciated!!! THANKS!
Old 07-24-2007, 09:45 AM
Coal Mining Director
onfire's Avatar
Don't take this wrong...but if the guy that's going to sd tune your car doesn't know how to set up a basic starter tune....you need a different tuner....you combo is very mild.
Old 07-24-2007, 09:49 AM
SonofaBish's Avatar
no problem... the builder isnt the guy that's going to tune it....
and he knows of a couple of tunes that are open loop MAF and closed loop MAP (or the other way around, i dunno)...
the guy tuning is very knowlegeable, but the builder adn I are just looking for somethign to save some time... if there is a SD only tune out there for 60lb injectors, we will be able to upload it and fire teh car up with minimal changes....
see what i mean?
Old 07-24-2007, 10:04 AM
onyx_rock's Avatar
Hey Bish,
Sounds like things are moving along nicely, Have you painted the hood yet?
Hope all goes well.
Brandon
Old 07-24-2007, 10:08 AM
SonofaBish's Avatar
Originally Posted by onyx_rock
Hey Bish,
Hope all goes well.
Brandon
Hood is painted.... she looks mighty fine...
i haven't forgotten about ya... my car has just taken THAT long .... i'll definitely be hittin' ya up when its all done!
Old 07-24-2007, 10:28 AM
anarchy99's Avatar
I might have one that can help you out. Same size cam, 60 lb injectors, 3 bar sd tune, m6, twin turbo, etc, etc... Shoot me an email address and I'll see if I can get it out to you later on today or maybe tomorrow.
Old 07-24-2007, 10:39 AM
SonofaBish's Avatar
PM sent
Old 07-24-2007, 11:10 AM
Dumb Ass Vette Moderator
ls1290's Avatar
To break in the motor, I would do a MAF based tune. Once the motor is broken in, ditch the MAF and do the SD tune. I broke my motor in with a MAF tune.
Keith
Old 07-24-2007, 11:16 AM
SonofaBish's Avatar
i will let him know ur suggestion
Old 07-24-2007, 12:40 PM
NYSS Guy's Avatar
I would highly suggest NOT using another car's sd tune. The sd tune takes into consideration boost characteristics when getting your fuel right. Your boost characteristics could be VERY different than someone elses.
As someone mentioned above, I would use a MAF tune to start the car up, DO NOT BOOST IT, and go straight to a tuner to start the SD tune.
Also, as a side note, SD tunes done in the summer time need to be kept conservative. As the temps drop in the winter, you would be running dangerously lean. Hope that helps.
Old 07-24-2007, 01:00 PM
cablebandit's Avatar
add a little RAF...take a little out of the low rpm ve table...make sure IFR is correct and fire it up.....after it is idleing and driving good, you can work on the booste ve table and timing but start way rich in boost and low timing and go from there.
Old 07-24-2007, 01:04 PM
SonofaBish's Avatar
well... he slapped the MAF on it and fired it up.... said it ran great.... so i'll suggest to him that we not go to SD until it is at the Tuner's place...
Old 07-24-2007, 02:07 PM
keep your foot out of it until its tuned no matter how tempting...
Old 07-24-2007, 02:12 PM
Boostaholic's Avatar
I had the same problem with aeromotive rails
You probably bolted the flanges to the rails then torqued them down to the manifolds right?
What you need to do is straighten them out, bolt the flanges to the manifold then push the rails down till the holes line up and put the bolts into the rail, that way the flanges dont get bent while torquing down the rails
Old 07-24-2007, 02:32 PM
SonofaBish's Avatar
i dunno what the problem was... w/e it was, they fixed it
Quick Reply: HP Tuners SD Tune - HELP Please!
