How well will a 244/248 cam work in a 346?
Old 07-25-2007, 11:37 AM
Restricted User
2001 Pewter WS6's Avatar
Default How well will a 244/248 cam work in a 346?
How well with a Comp XE-R 244/248 112 +2 work in a 346. The car has AS Stage 2 241 heads, CR will be around 11.1:1, 4:30 gears, M6.
Old 07-25-2007, 11:39 AM
dlove's Avatar
i have the comp 224/228 .534 .537 with TEA 241's ported and milled, with an A4 and n2o i run 11.02 @ 124 with alot more left to do
Old 07-25-2007, 11:43 AM
99blancoSS's Avatar
Yea So....... You cam is half the size of the cam he's talking about, whats your point?
With those gears in an A4 you should be ok, obviously its a top end cam and you shouldnt be looking for any power until you hit 4000 rpms.
Old 07-25-2007, 11:48 AM
Race your car!
JL ws-6's Avatar
that's about the sizeI have in my 402.. in a 346 that's gonna be a peaky cam with not so great low end I'm sure. I've seen people put bigger cams in 346 motors, but they are generally more race only stuff that spins to the moon.
As a daily driver I wouldn't do it, track only car give it a shot, as long as it's light enough and has enough gear it may run great.
Old 07-25-2007, 11:49 AM
Custm2500's #1 Fan
silver-mod-o's Avatar
I wouldnt do it... stay in the mid 230's IMO...
Old 07-25-2007, 11:51 AM
dlove's Avatar
With the gears you should be ok, obviously its a top end cam and you shold be looking for any power until you hit 4000 rpms.
crap I sware i'm dyslexic some times, it thought it said 224/228
Old 07-25-2007, 11:52 AM
Ericbigmac83's Avatar
Track car would be more understandable, i wouldnt do it for a dd though
Old 07-25-2007, 12:06 PM
mudflap1989's Avatar
I would definitely try to get the compression higher and maybe go +4 instead of +2, but I'm no cam expert.
Old 07-25-2007, 12:57 PM
Restricted User
It wouldn't be for a daily driver and as stated, M6 car with 4:30 gears. We will probably go a different route, if the consenses is that this is too big for a 346. We already have the cam and the main goal is ET.
Quick Reply: How well will a 244/248 cam work in a 346?
