Change of plans........
I was dead set on true duals. I have, sitting in my room, jet hot headers, two 2.5" classic chambered mufflers, and two 2.5" high flow cats. I met with the guy who was gonna weld it all up today. He put the car on a lift and walked it through with me and said he wont have enough room to run the duals. He said that he would fab up a y-pipe, run it into an I-Pipe, go over the axle, then into another y, and two pipes out the back. He will weld in one of my classic chambers into the I-Pipe, and he thinks this will be enough muffle.
Does this sound like a good setup? Its a little disappoint from being set on duals, but he said that this will be the better setup. Also he quoted my at $400 for all of this, sound good?
I've got another question, how much of a difference will mandrel bends make? For about the same price i can go with a custom true duals over the axle but the kicker is that all the bends are crushed. Or should i go with the y-pipe setup as stated above.
Pontiacerator
The duals can definitely be done, but I don't think there's going to be a big difference between them and the Y-I-Y pipe set up he's proposing. But one powerstick in the I is not going to be enough to quiet the system. He needs to build a catback with both powersticks like GMMG.
Most local shops don't do mandrel bends. Duals w/mandrel bends is best, and then you can work the options down from there ... duals with crush bends, next best, then Y w/mandrel bends, and so on. If you don't like what he's telling you, find another shop.
So theres not that much of a difference in HP between the Y and duals but what about sound? Everyone goes on about how duals is the best sounding system you can get. With the y setup and two powersticks will i be sounding close to duals?
