Power Steering Pulley INSTALL
I'm having a problem trying to figure out how to install the pulley on the snout of the power steering pump. I got the old one off using a puller from Auto Zone, and this tool is supposed to double as an installer as well. When I go to put it on, though, I can't keep the shaft from rotating while trying to pull the pulley on.
What am I doing wrong? I can't figure this out for the life of me...
Originally Posted by Dmoney
You have to remove that stud that goes in the middle of the puller that you used to remove the pully and put the stud that screws into the hole on the pump. I hope you understand.............
Yeah...it took me a while to figure it out, but basically, I wasn't getting the bolt tightened all the way before trying to draw the pulley on. Once I did that, it went on without much of a fight. I'm just hoping it is lined up okay now since this isn't a stock pulley.
Originally Posted by 00SS!
You get one of those billet ones?
I did not, but this new pulley wasn't very heavy...if I had to guess, it weighs a little more, but I'm just not sure. I only did this particular pulley for the ability to reach the power steering pump bolts directly through the pulley instead of having to pull it off just to get to those two bolts.
