Regular "Non-performance" Shops in the IE
Where do all you guys in the IE take your LS1 cars for "non-performance" work?
For example, my blower vent is stuck on the floor setting. The a/c and heating still works perfectly, as well as the fan speeds, it just won't switch from floor vents to upper dash vents, or to windshield defog, etc.
I figure Don Lee's/CMS wouldn't want to waste their time on stuff like this, and I don't really want to go to the dealer...
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
Originally Posted by Nine Finger 02 Z28
Sounds like a vacuum line came off...All of that stuff is vacuum controlled...Should be just a matter of finding it and putting it back together...
Maybe the vacuum line wasn't secured well after they replaced the valvesprings and it came off later that night?
I've looked under the hood for open vacuum connections but didn't see anything... I guess I'll have to look closer...
Thanks for the help! But I'm still curious as to what non-performance shops there are around that are "worthy" to take our LS1 cars to, LOL...
Hmmm... that makes sense. Awhile back, one of the valvesprings took a hit. I took it in to the shop and they fixed it, then later that night (after going to LACR) the blower stuck on the floor position.
The vacuum line runs below the pcm close to the fire wall (passenger side).Kind hard to miss if you know what your looking for (easily missed not knowing what you are looking for)...lol...Just look on the pass. side it is tied into the big wiring harness...
Thanks a million!
Well, I just checked again and I found the loose vacuum tube! All the connections near the PCM on the passenger side were intact, but I followed one that was traveling toward the rear of the car on the passenger side. It joined with a wiring loom, then emerged again near the back of the intake manifold, where I could barely see it. I felt around with my hand for open connections, and I found one, so I hooked it up, and I have air blowing out of the regular vents now!!!
Thanks a million!
Thanks a million!
