can anybody help with this??
i have an 06 gto that was tuned with ls2edit and the performance shop where it was tuned says they didnt lock the pcm, but efilive will not allow me to download the tune out of the pcm and the v2 is already licenced for the car. the pcm is a e40. does anybody know why this would be? thanks
Originally Posted by Eurospec2
If i understand correctly your trying to read the LS2Edit tune with EFI Live, and you have already Licensed your PCM with EFI Live?
yes thats right
Originally Posted by wait4me
It is for sure locked if ls2 touched it. The only way to unlock it is to put that computer back to stock using that ls2 cable i believe.
Here is the answer I got from ken at carputing.
Mike,
The current LS2-edit locks by default, But the tuner can check a box
to not lock the file. We are working on a release that will unlock by
default and make the programmer select lock if needed. The default
setting has caused problems were tuners don't realize they are locking.
Any LS2-edit tuner can unlock the E40 ECM.
Ken
Mike,
Ken
https://ls1tech.com/forums/nitrous-oxide/749133-flip-switch-nitrous-tune.html
look at that thread it has some info on what I used to make your tune.
Originally Posted by waterbug1999
Hey, when you gonna do my tune..
Mike sent me the new COS and Cal but you need to tap into a PIN on the PCM to make it work.
Mike - Can you send me a copy of your 05 GTO stock file? I need the MAF table for my TB SS.
Originally Posted by DrkPhx
Hey, you were the one bingeing all weekend.
LOL.. Me? Never!!
You know what pin/wire it is? Maybe once I get moved and will be closer to everyone, we can do this one day. My car feels like a turd on motor!
