rough idle and service engine soon light?
Old 08-01-2007, 02:09 PM
Camaro396's Avatar
Default rough idle and service engine soon light?
last night i noticed on my way home, my car at idle at a light, was kind of idling rough, between 400-600 rpm up and down, and at some points felt like it was about to die, i didnt think much of it cause i was tired, but this morning when i left for work i noticed it was doing the same thing, only when i was about a block away from work, it threw a service engine soon light. the car is stock other than a lid that i put on a month or so ago, and open y pipe. it has 95,000 on the clock now, any ideas what it could be? it hasnt had plugs and wires in a long time, but i doubt thats it..
Old 08-01-2007, 02:44 PM
Camaro396's Avatar
anyone? i hope it gets me home from work without dying..
Old 08-01-2007, 03:09 PM
rd_ls1_z's Avatar
Check the code an post it up. Sounds like it could be a misfire. What does it do when you accelerate?
Old 08-01-2007, 03:49 PM
Thebeast431's Avatar
My guess would be O2's. Check for codes.
Old 08-01-2007, 03:56 PM
Camaro396's Avatar
runs great under acceleration, just misses a lil slowing down coming to a light and idling.
krayzie7th's Avatar
what about in cold starts? does it do it?
Old 08-01-2007, 03:59 PM
jmm98LS1's Avatar
My bet: EGR valve stuck open causing a rich condition at idle......almost sounds like you got a cam idling but runs fine otherwise. Get the code scanned & you'll have your answer.
Old 08-01-2007, 04:09 PM
rd_ls1_z's Avatar
If it's good under acceleration, not a misfire. Now, I'm also leaning towards O2 or EGR, get it scanned Too bad we can't figure these things out without a scanner....
Old 08-01-2007, 04:20 PM
Camaro396's Avatar
haha your telling me. but yeah it almost does sound like it has a cam at idle. it did it cold start up this morning too, just not as bad as it did after it was warmed up. i hate thinking somethings wrong with my baby
Old 08-01-2007, 06:11 PM
krayzie7th's Avatar
if it did it at cold start then its probably not your o2 sensors, its probably your egr valve stuck open.
Old 08-01-2007, 07:25 PM
The EGR is an easy fix. Just get rid of it if emissions are no problem.
Quick Reply: rough idle and service engine soon light?
