Jack Points
Old 08-04-2007, 02:09 PM
transamws6_97's Avatar
Default Jack Points
Ok so some friends and I helped install headers on my friends lt1. When I usually jack up the car I do it from the side and jack up from the plastic piece and then put a piece of wood on top of the jack stand and set the car on that. But when they installed the headers he jacked the car up from the front using that big metal plate under the motor and then used the jack stands under the a arms. Is that the best way to do it?
Old 08-04-2007, 03:15 PM
98redM6's Avatar
I've done that lots of time. It's a good centerpoint and that piece is sturdy enough to jack from.
Also don't ever jack from the plastic piece on the sides (jacking puck). It'll cause your fenders to stick out, if they aren't already like that. I suggest you jack it from the frame rails.
Old 08-04-2007, 03:54 PM
See I used to jack from the frame rails but they started to cave in a lil bit so I said screw that and started using the plastic jacking puck
Old 08-06-2007, 12:20 PM
ttt whats the best way to jack up the front of the car
Old 08-06-2007, 01:12 PM
Shockwave179's Avatar
Frame Rails
http://www.installuniversity.com/ins...sity/index.htm
Go to Install Documents on left
Then scroll down until you get to Miscellaneous
Lift Points should be the last thing listed under Miscellaneous
Old 08-06-2007, 02:31 PM
ae13291's Avatar
for some reason my front k member has started to cave in from jacking it there to much, am i doin somethin wrong
Old 08-06-2007, 02:33 PM
5301113's Avatar
Same here
