Oil leak coming from in between the oil filter and motor
Ok guys, here's my problem. My car had been blowing oil onto my pan, and immediately I thought it was the rear main seal. But after a few oil changes and monitoring it more closely, I noticed that it is coming from where the oil filter meets the motor. I know there is some sort of gasket there, but does anyone know what exactly it is or called? Part number? I tried NAPA and Murray's and they didn't have anything like a oil filter gasket or something close to that. It is not a lot of oil, but I need to get it fixed for piece of mind. Let me know your thoughts, thanks!
Matt
Matt
Are you talking about the gasket for the oil diverter plate (bolted on the pan right above the oil filter by two 10mm bolts)? Other than that, just the rubber filter that comes on the oil filter. I hate to ask, but did you take off the old oil filter gasket, sometimes they stick on the mating surface?
Well, if you ever wanted to do an oil cooler.. W2W sells a kit that bolts up to where the diverter plate is.
http://www.w2wpowertrain.com/p-53-oi...k-for-ls1.aspx
If not, they could probably hook you up with a new gasket for it since they probably supply one for their kit to seal.
Originally Posted by Matt D
I don't want to go that route. There has to be a part number for the gasket thingy.
i thought my threads might have got stripped and i might need to buy a new pan, but maybe there is a gasket that will fix this.
PM me if you ever find out
