TR230 M6 around town
Old 05-20-2003, 09:14 PM
DaleMX's Avatar
Default TR230 M6 around town
So what is a 230 like around town in an M6? How's 6th at about 1500 rpm? What kind of gas mileage can you get?
I having a big debate with myself between the 230 and the 224. I'm leaning to the 230 but am wondering if its just a bit much for the street.
Old 05-20-2003, 10:06 PM
Krazy98Z28's Avatar
Default Re: TR230 M6 around town
i dont find it much different than my XE-R 224/224. Go with the 230 you wont be dissappointed. I already want a bigger cam myself
Old 05-21-2003, 01:08 AM
verbs's Avatar
just don't do an aluminum flywheel and you'll be fine.
Old 05-21-2003, 03:44 AM
D(irecto)r Pepper
Raughammer's Avatar
Do you want the bigger cam for the extra power? for the extra lope? or for better time at the strip?
Take a look around and see who was running what size cam when they went as fast as you want to go someday.
I would recommend the smaller of the two.
Goodluck.
Old 05-21-2003, 05:04 AM
DaleMX's Avatar
Thanks for the info guys, The car is real light, about 2200 to 2400 lbs. So maybe less torque at lower RPM is a good thing. I'm not sure. I like the dyno graph that Thunder put up on the 224, but I like the sound of the 230. The car is not yet finished, but it's cam time if I'm going to do it so I'll make a decision soon. I am just worried that the 230 might try to surge a little in 6th gear and force me to run in 5th. If that's not an issue I'll run the 230 and titanum retainers. The car also has LT's Y and bullets turned down before the axle, LS6 intake, custom intake filter setup, stock MAF, stock LS1 heads trimmed down .008 and a 5 angle valve job. Rear is a ford 8.8 traction lock with 3.73 gears.
You should see the drive shaft on this thing, it's all of 17" long!
Old 05-21-2003, 07:38 AM
Viper's Avatar
Dale
What kind of car is it in?
Old 05-21-2003, 07:55 AM
Krazy98Z28's Avatar
IS that a Factory Five. I worked for them for 2 years. I always wanted to put a LS1 in one.
Old 05-21-2003, 10:34 AM
RB185AFM's Avatar
I am running the ASA cam. It also has a 110 LSA. I have stock 3.43 gears and in 6th I do get a little idle surging from 60 to 70 mph.The cam does not like anything under 2000 rpm. I plan on putting in 4.10's to solve that problem. But it is not to bad.
Old 05-21-2003, 11:31 AM
DaleMX's Avatar
The car is a Classic Roadsters Sebring MX. I thought about a Cobra, but really like the old Austin Healey 3000 that the MX is modeled after.
Old 05-21-2003, 01:29 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
I drove around town with a 230/224 LA111 TR cam around town and on the highway with no problems.
With stage 2 GTP heads and the TR cam I got 26 miles to the gallon on the Highway.
Coach
Old 05-21-2003, 09:10 PM
mobius's Avatar
coach you get 26 mpg with a non lock up a-3? how is driveability for an everyday driver?
Old 05-21-2003, 09:13 PM
mobius's Avatar
John is your website down?
Old 05-21-2003, 10:34 PM
verbs's Avatar
I get no surge in 6th gear period, and that is with an aluminum flywheel.
Old 05-22-2003, 12:45 AM
Abdulla's Avatar
Hi,
Just wondering why beeing away from Alum. flywheel is better ?? Just want to know because I have one and want to be sure that everything is OK
Thanks
Old 05-22-2003, 06:59 AM
Viper's Avatar
Lighter mass ( aluminum ) makes it more difficult to launch the car.
Old 05-22-2003, 07:47 AM
I am in the process of changing the Hot Rod to a A3. She has been a M6. I did not have any surge at all in 6th gear. She might of surged in 1st a little bit. The 230 cam is a great cam. Lots of HP and great to drive around town for me.
Coach
Old 05-22-2003, 12:00 PM
DaleMX's Avatar
Thanks for all the input everyone. I'm going to go and order my 230 today.
Old 05-22-2003, 12:41 PM
verbs's Avatar
Hi,
Thanks
Abdulla, the reason I said that is because he is worried about surging. An aluminum flywheel will cause more surging than a steel flywheel will. As long as your car drives fine I wouldn't worry about it. It's not a problem in my car either...just leads to more bogging at the track and a lot more surging at low rpms.
Old 05-23-2003, 11:19 AM
Abdulla's Avatar
Thanks verbs
Yeah I noticed that
Good luck
Old 05-23-2003, 08:42 PM
DaleMX's Avatar
Well I ordered the 230 yesterday from Thunder and recieved a UPS number tonight. Man thoses guys are fast. Also ordered a dual sprocket and chain from Scoggins Dickey and got a UPS number on that too. By the way, the order conframation has the correct part numbers on it. Thunder rocks!
Dale
