cam w/out tune ??
cam w/out tune ??
i just got a cam from to put in my ls1 and was wondering if i could do it with out tunning i was looking on ls1howtwo.com and they said certain cams do not need tunning to run the car here the stats of mine
Lobe lift:
0.326" I
0.568" E
Valve lift (1.7 rocker):
0.554" I
0.580'' E
Valve lift (1.8 rocker):
0.587" I
0.601" E
Advertised (total) duration at 0.006":
261° I
277° E
Duration at 0.050":
208° I
224° E
Lobe separation angle (LSA):
117
Lobe lift:
0.326" I
0.568" E
0.554" I
0.580'' E
0.587" I
0.601" E
261° I
277° E
Duration at 0.050":
208° I
224° E
117
ya i think the oil is supposed to go into the engine...not under the car? haha just kidding
but that cam should be fine on stock tuning with such a wide lsa and low duration. is the car an automatic or manual?
i think ls6 springs are good to 580. so pushin it with the 1.7's and not a good idea with the 1.8's. just get some comp 918's. That looks like a nitrous cam with the larger exhaust numbers.
Moderator
My car ran fine with the TR224 cam before it was tuned. I just did not get a lot of power before it was tuned. That cam should be fine to drive for a while without a tune, but I would get one ASAP.
As for the springs, don't take the chance. Get some 918's. If you're on a budget, buy some used ones.
