Write up on installing Harland Sharp rockers
Old 08-07-2007, 05:54 PM
00 Freak's Avatar
Default Write up on installing Harland Sharp rockers
Just wondering if there is a write up on installing the rockers.
Old 08-07-2007, 06:06 PM
teke184's Avatar
not really a need of one.
pull the stock rockers off, remove the pedestal mount, mount and torque the new rockers down.
Old 08-07-2007, 07:07 PM
Emoney97ss's Avatar
yeah i was wondering the same thing i just got a set haven't really looked at them.. i've takin the old one's off before, but these have some new screws and some other things that look like they go in the top before the bolts...
Old 08-07-2007, 09:12 PM
HEMIETR's Avatar
Its a no brainer guys, unless you have the adjustables.
Old 08-07-2007, 09:50 PM
00 Freak's Avatar
no adj here.
Old 08-08-2007, 05:07 PM
3.4camaro's Avatar
then there is no writeup neccessary. Just bolt them on to 22 ft/lbs, and use red locktite.
Old 08-10-2007, 03:51 PM
Viper's Avatar
LS1Tech 20 Year Member
" pull the stock rockers off, remove the pedestal mount, mount and torque the new rockers down."
If they are Harland Sharp modified stock rockers, you need to leave the pedestal in. Just put the new rockers on, put locktite under the washer head and torque to 22 ft/lbs. The HS modified rockers come with a hex bolt head so you'll need that in a socket. I don't recall the exact hex size but buy a small kit with several sizes. Take the bolt to the store if you need to.
Old 08-10-2007, 05:46 PM
TheLS1Kid's Avatar
^Thats the perfect write-up.
It's really not hard. You just gotta get in there and do it.
Old 08-10-2007, 07:22 PM
Emoney97ss's Avatar
you don't need the pedestal if they are the bright orange one's?
Old 08-10-2007, 07:24 PM
00 Freak's Avatar
Yeah I was told I didn't need anything? Yes they are the orange ones
Old 08-10-2007, 09:58 PM
Emoney97ss's Avatar
so you take the old rockers off along with the long metal piece and install the new one's by themselves....
Old 08-11-2007, 07:50 AM
RZRSEDGE's Avatar
Yeah, they come with their own pedestal for each rocker. After I did it a time or two on my car, I can have the valve covers off and the rockers off in less than 20 minutes on a cool engine. And I still have the factory located coils. Not hard at all. One word of advise though is to get a 3/8 torque. wrench if you don't already have one. An adapter and the proper size allen head socket make it hard on the number 7 cylinder. Good luck and hope this helps!
Old 08-11-2007, 09:47 AM
LS1Beginner's Avatar
In my case I used the HS 1.8's and had to use a shorter pushrod (7.350 vs. 7.400). Check the pushrod length - the motor barely ran with a 7.4 pushrod (no compression).
Call the tech line at Harland Sharp - they explained the whole pedestal thing to me.
