fast intake does not fit...problem solved
I just got done setting a fast intake on my 99 C5. I have .037" milled heads. The intake would not sit down on the heads all they way. I found that the bottom of the intake was hitting the valley cover bolts. I swapped out the hex heads and installed 10 button head bolts, problem solved. Just thought i would give everybody a heads up if you didn't know that already.
CWB
CWB
