Calculating Compression Ratio
Old 08-09-2007, 10:10 AM
1INSANEGTO's Avatar
Default Calculating Compression Ratio
Ok I am lost here. Never really kept up with the info.
Here is what I know about my motor.
346ci
Diamond -8.66 cc dish pistons
Lunati pro mod rods 6.125 length
Stock crank polished
I am sure someone has did this before
The calculation for determining compression ratio works out like this:
CR=(D + PV + DC + G + CC) / (PV + DC + G + CC)
CR = Compression Ratio
D = Displacement
PV = Piston Volume
DC = Deck Clearance Volume
G = Gasket Volume
CC = Combustion Chamber Volume
http://www.circletrack.com/techartic...e_compression/
Old 08-09-2007, 10:22 AM
NassyVette's Avatar
346ci
D = Displacement
PV = Piston Volume
G = Gasket Volume
List your cam specs for accurate scr and dcr, also what is the compressed thickness of your head gasket, your cylinder head volume as well as deck height. We need all of the info for an accurate compression ratio and quench.
Old 08-09-2007, 12:08 PM
1INSANEGTO's Avatar
Cam specs. 231/226 601/591 115lsa
Deck height. Stock LS1 Block
Head gasket std
Cylinder head volume; not sure what CC they are
Old 08-09-2007, 12:21 PM
LS1TECH Sponsor
tt427ls1's Avatar
Head gasket std
We need to know the CC of the head. Your going to have to find that out. Makes it alot easier
Old 08-09-2007, 12:27 PM
stevieturbo's Avatar
http://www.csgnetwork.com/compcalc.html
Old 08-09-2007, 01:43 PM
1INSANEGTO's Avatar
ok.
Enter Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') -8.66
Compressed Head Gasket Thickness 0.021
Piston Stroke Length 6.125
Head Gasket Bore Diameter ?????
Cylinder Bore Size???? 4.030????
Bore/Stroke Designation Type
1 = Inches
Piston Deck Clearance Negative If ABOVE Deck (Use '-') : ???????
Heads are LS6 Patriot performance stage III Heads.
Old 08-09-2007, 02:05 PM
ibgoatin's Avatar
maybe these will help
http://www.c5frc.com/calculators/Co..._Calculator.htm
or this
. http://www.rbracing-rsr.com/compstaticcalc.html
Old 08-09-2007, 03:14 PM
1INSANEGTO's Avatar
What is the deck height on a LS1? Thats the only number I am missing
Old 08-09-2007, 03:58 PM
black98ws6ta's Avatar
Standard is around 9.420....but if your block was decked it could be different. Also I dont think your compressed thickness on the gaskets is .021 unless im missing something, most gm gaskets are .056?
Old 08-09-2007, 04:35 PM
Brains's Avatar
How are you guys calculating DCR? I'd be curious where my setup stands...
Quick Reply: Calculating Compression Ratio
