Which head sensor question...
Well I swapped my 853 stock heads with the new 243's and everything is going well. However in the mix of everything I can't remember if the driver or passenger side get's the sensor and which side gets the plug. I can't seem to find any wire that matches up the the sensor on either side of the heads.
Thanks
Thanks
It's my understanding the stock 241's are the same for either side and either can be used. ECT/connector should be on the drivers side just forward of the #1 cyl, so passenger side (by #8) has the plug.
