Pulley, gears, or save for cam?!
I have the mods listed in my signature. I am at a point where I would like to do a cam but unfortunately I cannot decide on what one to purchase. When the decision is made it will be somewhere in the middle of the road. (i.e. 228/232) Anyways, would I see more benefit now by getting a pulley? Would you recommend a gear swap? Any opinions would be appreciated. Thanks.
I would not worry about gears too much unless you are planning on buying a bigger size cam. From the looks of your mods you pretty much have all the bolt-ons minus a pulley. I would buy the pulley and then look into getting a cam. My cousin ran the F11(228 230) with the stock 3.42 gears and his car pulled like a freight train. Plus if you get gears IMO the rear is more likely to go faster vs. leaving the stock GM gears in there. Goodluck
4.10 in an m6 car can make a .5 second difference. I put 4.10 in my car, and will never look back. Out of the hole the car pulls so much harder. Id do what everyone is saying.. Gear(what ever size you decide) then wait for who ever does the pulley to do the cam. I just did my pulley yesterday, and it was a pain coming off, and a pain going back on. The bolt was easy to get off, the rest sucked. Your car with a 4.10 and pulley should be able to hit low 12's on a good tire.. Not sure what your running now.
Now not only do you have to decide on a cam, but you have to decide on a gear, and manufacture. Id suggest genuine gm with motive install kit. I have no whine at all from mine. Good luck.
Chris
Chris
Restricted User
I agree completely. I recently went w/ 4.10s and there's a hell of a difference! Definitely buy the AAM gears (same company that makes them for GM) and the motive MASTER install kit. you're gonna want to have those bearings changed if you've got more than 60k miles on the car. It just makes sense.
Hi all you, don't meen to hijack just got some questions.
How does 4.10's effect gas milage? Obveisly to the negative, but how how much?
And how much does the gear swap cost (if I do the work)?
Too be honest with you, it was easier then the crank pulley i did yesterday. That thing was a damn pita.
As for gas mileage i dont drive my car a ton, but normal driving when i last filled up i got about 17 mpg.. On the highway in 6th i can get about 23mpg. Not to bad.
Chris
