Sponsored by: DashLynx
Here you go - engine bay fastener list w/ sizes
Old 08-13-2007, 10:35 PM
bsf
bsf's Avatar
Default Here you go - engine bay fastener list w/ sizes
I replaced most of the visible fasteners in my 98 Trans Am engine bay with chrome-plated fasteners. Here is the list I created, with my sources and part numbers.
98 Trans Am Engine Bay Fastener List
I cannot guarantee 100% accuracy. For example, I edited my list after installation in a few instances where I thought longer or shorter bolts/screws may be appropriate. Most fastener replacements are same class (grade) or stronger than OEM, but there are a few substitutions of lesser class. I am not responsible for any damage or injury caused by use of the fasteners in my list. Also, I have not included any fasteners I used to plug holes in the wheel wells.
This is not an attempt to undercut any sponsors that provide fastener kits. I hope people find it helpful.
Edited 02-24-2010
repaired file link
Old 08-14-2007, 05:10 AM
White.Lightning's Avatar
Thanks so much for your efforts. This is a nicely put together document. One of these days I will go through this and order everything up.
Thanks again
Andy
Old 08-14-2007, 11:10 AM
NDFORSPD's Avatar
do you have a pic/pics of a completed engine bay?
Old 08-14-2007, 12:40 PM
bsf
bsf's Avatar
I have no current, good pics and I have not installed FRC's or stainless covers yet. When I complete my engine bay I will post pics in the mega-engine bay thread.
Old 08-14-2007, 05:46 PM
Ws6Extreme's Avatar
I will tell you the best place to get the stainless button head bolts hands down is Fastenal. Now you will have to polish them yourself, but I got 200 pieces for $25!!!!!!!!!
Just thought that I would pass this info on.
Outstanding list by the way!
Old 08-14-2007, 07:11 PM
94blownz281's Avatar
if you polish them whats going to keep them from getting surface rust on them?
Old 08-14-2007, 07:27 PM
Ws6Extreme's Avatar
Quality grade stainless does not rust my friend. At the most you will have water spots, but again this would be a Do It Yourself approach.
There are sponsors on here that sell Stainless kits already polished that if you would like can be purchased, but you won't come close to the price.
Old 08-14-2007, 08:54 PM
bsf
bsf's Avatar
That is some good information. Are the heads smooth enough so that a “mirror” finish can be attained through two stages; polish and buff without sanding?
ETA
Note that almost all my part numbers are for chrome-plated hardware, not polished stainless.
Old 08-14-2007, 08:56 PM
Ws6Extreme's Avatar
The Ones that I have seen so far look great, and should not have much of a problem. The only problem will be that Stainless is ONLY GRADE 5 equivalent so they are NOT advised where Grade 8 is required......
Old 08-14-2007, 09:09 PM
okay wasn't sure if polishing them would make the surface weaker? i replaced the ones for my camaro that hold the front clip on so far and bought them from Homedepot. only other ones i need are the fenders,hood bolts and nuts. wonder how much that would cost me since it cost you $25.00 for 200 which is awesome man.... there is two fastenal building around me but i think only one is a store. i will have to check it out and i have a buffer wheel and compound for the job.
Old 08-15-2007, 03:04 PM
LawmanSS's Avatar
I added your list to the appearance "hall of fame" thread.
Old 08-15-2007, 03:17 PM
presto_z's Avatar
congrats on the achievment and thanks for the list
Old 08-27-2007, 11:15 PM
do i have to know what the exact size bolts are that i bring to Fastenal or will they size up the bolts/washers for me?
Old 08-28-2007, 06:54 AM
Ws6Extreme's Avatar
You could do either or. They are very helpfull.
Old 08-28-2007, 07:28 AM
Thanks!
Old 02-22-2008, 05:56 PM
presto_z's Avatar
it says the file is no longer available
Old 02-22-2008, 06:22 PM
sleepinghawk's Avatar
Try it again, it worked 2 times for me then it said what you said then I tried it again and it worked.
Old 02-22-2008, 06:26 PM
presto_z's Avatar
ok, it works now.. hmmm interesting
Old 02-22-2008, 07:09 PM
6LITEREATER's Avatar
Wow! You went through a lot of work to make that list... Thanks! So, what did your total cost end up being (I'm too lazy to calculate )?
Old 02-22-2008, 07:24 PM
Hmmm... Am I missing something? I did a rough total and it looks like you spent more than if you would have just bought the kit for $138:
http://store.specializedstainless.co...t/Detail?no=82
Quick Reply: Here you go - engine bay fastener list w/ sizes
