Help, 4L60E, no 3rd
Old 08-14-2007, 07:53 PM
KAS
KAS's Avatar
Default Help, 4L60E, no 3rd
i have a 96 imp, basic mods, f body maf, air intake, brian herter modded computer and x pipe exhaust.
My Problem; transmission went, all metal through it, (yeah i pound on it) Well,(shortened story) I had a trany built by Performabuilt, when 1st unit was installed, by transmission shop, 35yrs in biz, there was no 3rd gear.
Performabuilt sent another unit, said this one they tested in a car. And they installed this one, YEP no 3rd again!
I have my stock computer, i tried that, in case, no difference.
so i'm at a loss, so is the trany shop, they even installed new speed sensor just in case.
the trany shop sent it to a local shop with computer diagnostics, they scaned it, with no codes, no problems noted, all selinoids were told to open, they suggest, bad trany.
My original trany had no problems shifting.
Question? is there any electrical thing that would cause this?
Mr. S
Old 08-14-2007, 08:40 PM
LS1Tech Sponsor
performabuilt2's Avatar
disconnect the connector on the transmission this will put the trans in limp mode it will default to third gear if it has third this way then you have an electric issue
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 08-14-2007, 08:52 PM
LS1Tech Sponsor
Kas, I am a GM tech is it possible for you to send me the data stream from this transmission when it is commanding third gear so i can analyze it.
__________________
Old 08-14-2007, 10:40 PM
KAS
KAS's Avatar
I will ask, the 2nd shop might have that capability,
disconnect the main wire harness?
Old 08-14-2007, 10:50 PM
LS1Tech Sponsor
performabuilt's Avatar
Yes disconnect the harness this should force third you will need to compare Rpm both ways and see if it happens if it does then the trans is capable of making the shift , Though personally I am sure it can since I tested yours personally it made every gear without incident in our test mule van,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-14-2007, 11:00 PM
KAS
KAS's Avatar
ok, will have them do that in the morning.
now, if its electrical, what would it be?
harness?
is a 1994 buick RM harness the same?
Old 08-14-2007, 11:07 PM
LS1Tech Sponsor
yes unplug the transmission it will make it go into third if it does go into third then there is an electrical problem if it starts in first then we have a problem
__________________
Old 08-14-2007, 11:10 PM
LS1Tech Sponsor
kas, if it goes into third with it unplugged i would have them inspect the harness coming down from the pcm to the tranny for any bad wires, pinched wires, bare wires
__________________
Old 08-14-2007, 11:11 PM
LS1Tech Sponsor
Depends on the year on the harness 94 one type 95 early to to late different and 96 again different.
__________________
Call 888-744-6542
Quick Reply: Help, 4L60E, no 3rd
