LS6 Intake Install - Any benefits to leaving the stock coolant lines?
Old 08-17-2007, 08:09 PM
Tram's Avatar
Default LS6 Intake Install - Any benefits to leaving the stock coolant lines?
I know some guys are removing them and blocking the rear 2..
I know some guys are leaving the stock lines in place..
Is there any benefit to removing them?
Is it better for the car to leave them?
I have heard leaving them helps keep the #7 cylinder cool??
Just curious..
Thanks
Jeff
Old 08-17-2007, 08:12 PM
bsf
bsf's Avatar
That is why I did not block the back ports off.
Old 08-17-2007, 08:16 PM
Tram's Avatar
Yeh, it just seems, they took the time to put the lines there for a reason..
Old 08-17-2007, 10:24 PM
DropTopBird's Avatar
I left mine in. My car didnt have a cooling problem before so I didnt feel like fixing something that wasnt broken. It just took about two hours to grind down the tabs on the bottom of the intake w/ a dremel.
Old 08-18-2007, 10:13 PM
theblur98ss's Avatar
I didn't think they would fit with an LS6???
Old 08-18-2007, 11:14 PM
Pontiacerator
RevGTO's Avatar
That's one reason I decided to leave them ... besides the fact that it is cheaper and easier just to knock the ribs off the LS6 intake.
Old 08-18-2007, 11:45 PM
Tram's Avatar
You have to be a bit crafty to make them fit..
I hear it's not brain surgery, and since I am a noted brain surgeon, I should be ok..
Old 08-19-2007, 04:33 AM
camaroguy26's Avatar
I swapped mine out with the ls6 coolant pipe and rear plugs and haven't seemed to have a problem. But I don't have really hot weather, don't run at the track much, and have the 160 degree t-stat in with tuned fans
Old 08-27-2007, 09:42 PM
00silverGTP's Avatar
anyone have pics to where to grind on the ls6?
Old 08-27-2007, 10:12 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I just used a dead blow mallet and flattened them out and it seated just fine.
Old 08-29-2007, 04:53 PM
was hoping someone had pics..................
Old 08-29-2007, 05:05 PM
Juiced2000SS's Avatar
Hammer and a sharp chisel. Took the grid right off the bottom. Almost too easy.
Old 08-29-2007, 05:12 PM
1999Transamman's Avatar
I just used two of the ls6 coolant pipes, no cutting or worrying whether or not it will cool properly. The write up on LS1HowTo.com is a good guide, I followed it to the dot and havent had any problems.
Old 08-29-2007, 08:19 PM
DaddySS's Avatar
put chalk or similar marking material (paint etc.) on the pipe and press the manifold down into place, you should then have a good guide for where to trim.
Old 08-29-2007, 10:11 PM
Pontiacerator
RevGTO's Avatar
Here's a thread with the pics: https://ls1tech.com/forums/generation-iii-external-engine/697788-grinding-ribs-ls6-intake-pics.html
Old 08-30-2007, 10:16 AM
GT Griller's Avatar
DAAAYYMMNN.....2hrs? We just used my friends grinder and took off all the little ribs in like 10 minutes.....The whole install didnt take 2 hrs.
Old 08-30-2007, 03:50 PM
silverLSWON's Avatar
you can use 2 ls6 pipes and have them T into eachother, but the truck pipe angles higher so its a bit easier to run the line to it
Old 08-30-2007, 09:40 PM
SSkillz's Avatar
damn now I can put my intake on...
Old 08-31-2007, 08:50 AM
Amoretti's Avatar
I used what looked like a giant pair of nail clippers (really I think they were tile clippers or something) and just clipped off all of the ribs that were in the way. Then I just Dremel'd down what was left to smooth it out. Worked like a charm, was free, and easy.
