Need heads for ASA cam
Old 08-19-2007, 10:25 PM
SSsuperdave's Avatar
Default Need heads for ASA cam
What is a good performance head that's not radical or 'spensive that will complement my cam?
Old 08-20-2007, 08:17 AM
blkbird's Avatar
How much are you willing to spend?? Give Patriot a call, they have some good heads that wont break the bank!!
Old 08-20-2007, 10:12 AM
ttt..
Old 08-20-2007, 01:13 PM
GR33N GoblinM6's Avatar
ported LS6's or patriot 5.3 stage II's
Old 08-20-2007, 02:02 PM
voda1's Avatar
Patriot 'LS6 style' heads with 59cc chambers to get your DCR up.
Old 08-20-2007, 06:09 PM
JBIRD02's Avatar
I also have the ASA, and with that cam, looking at flow #'s past .525 lift wont do you any good. You're going to need a set of heads with good mid-lift #'s. All of the heads mentioned are good heads, but these (CLICK HERE) are the ones that are meant to go with that cam. The only problem I see with these is you might need to check ptv clearance since I see you have the quick lift rockers.
Old 08-20-2007, 10:33 PM
few questions about those heads. What will the comp ratio be and will it be pump gas friendly? Also, with milled heads, how do you get the intake to seat properly. I see those heads are suited for the cam, but I'm afraid it won't be drivable on a street car.
Old 08-21-2007, 12:12 AM
ttt..
Old 08-21-2007, 08:57 AM
jmm98LS1's Avatar
Holy crap, the problem I see with those is $1k PER HEAD!! A couple hundred bucks more & you're into some AFR 205's.......
Old 08-21-2007, 09:44 AM
JBIRD02's Avatar
Well, it depends on the gasket used of course, but its my understanding that with a stock gasket, comp. ratio will be 11.25 or 11.3 (I've heard both from the people I've talked to). As far as the intake goes, I'm not exactly sure. I'm also planning on getting these heads, and will talk to the vendor about it. I also need to talk to some people I know with milled heads to see what they have done.
Yeah, I know they're definately not cheap. They are more than some of the other heads out there, but still cheaper than AFR's, Trick Flow's, etc. It just seems that since these heads are designed for the ASA cam (and its low lift) that it would be the right choice. I may be wrong, theres a lot of really good heads out there that are definately cheaper.
To be honest, I havent seen anyone so far that has heads (of any kind) and the ASA cam. I would love to see some #'s from anyone who does!
Old 08-21-2007, 10:30 AM
I called Patriot and they suggested CNC'd 243's. I'm not sure if they use the same size valves, but if they do I could get a set of bare, CNC'd heads, reuse my valves and springs for $895.00.
Old 08-21-2007, 10:38 AM
JBIRD02's Avatar
Sweet! Well, let us know what you decide, and post up the results. Like I said, I havent seen any #'s or times from a head/ASA cam combo yet!
Old 08-21-2007, 11:29 AM
Hennytime's Avatar
the patriots have larger valves. honestly, those are your best bet, or the tsp heads with ls6 springs. i think the tsp ones are 900 bucks with the ls6 springs and flow about the same as the patriots
Old 08-21-2007, 11:46 AM
AU N EGL's Avatar
Check the air flow between the two. These GMs flow better up to 575 lift.
I have these heads and still working with a few ppl on cam choices for road racing, dont care about street use.
Old 08-21-2007, 06:30 PM
camaross383's Avatar
Well, it depends on the gasket used of course, but its my understanding that with a stock gasket, comp. ratio will be 10.9x or 11.0 (I've heard both from the people I've talked to). As far as the intake goes, I'm not exactly sure. I'm also planning on getting these heads, and will talk to the vendor about it. I also need to talk to some people I know with milled heads to see what they have done.
check my sig........
435rwhp 408tq dynojet
Old 08-22-2007, 07:35 PM
JBIRD02's Avatar
Sweet! Thanks
I figured these heads would be worth about 40rwhp which would put me at 432rwhp, so I guess I was pretty close!
Old 08-23-2007, 09:17 AM
voda1's Avatar
"GM 88958622 LS6 CNC d Cylinder Heads"
In GMPP part #88958622 with 250cc port volume and 61.9cc combustion chamber.
Don't forget to consider port volume when looking at flow numbers.
Corrected old info.
Old 08-23-2007, 07:32 PM
Sweet! Thanks
I had very similiar numbers to yours when I was cam only... it was 397/381 with no pulley and full exhaust. So yeah I think you would be real close to my numbers with the same heads, and trust me the area under the curve is awesome.
Old 08-24-2007, 02:39 PM
Judge Smales's Avatar
What length pushrod are you using and do you know what compression ratio is now with these heads/cam. Using pump gas?
Old 08-24-2007, 03:48 PM
JBIRD02's Avatar
comp. ratio should be 11.3
Quick Reply: Need heads for ASA cam
